What you got today
10349 posts / 0 new
sandalian
sandalian's picture
Last seen: 12 months 12 hours ago
Nice score!
I’ve been wanted to have one of Sinner’s creation since he was only build a custom host.
I'm switching my BLF account into LumenZilla. Thanks!
Bak
Bak's picture
Last seen: 2 months 6 hours ago
MascaratumB
MascaratumB's picture
Last seen: 55 min 42 sec ago
Bak wrote:
Is it the Reylight AAA Ti? Shocked
Bak
Bak's picture
Yes it is. The Pineapple Ti Mini. Not really a budget light in general but pretty budget for being Ti and small batch. My first Ti light so I am very happy. The Nichia 219B 4500K R9080 high CRI is very nice Smile
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 4 hours 38 min ago
Sandblasted Ti always looks amazing.
NeutralFan
NeutralFan's picture
Last seen: 1 day 15 hours ago
Great looking flashlight and LED Bak!
I’d rather use my flashlight around the house than turn on the lights.
rdhood
Last seen: 7 months 2 hours ago
A Sofirn C01R and Convoy C8+. Both are excellent!
scalpel_ninja
Last seen: 56 min 2 sec ago
Current Collection:
Inova X5 | Maratac Titanium Inspection AAAx2 XPL-G2 swapped to Nichia 219B sw45K | Wowtac A2S NW | Noctigon KR4 Ti/Cu E21A 4500K + 18350 tube | Thrunite Ti3 NW | Wurkkos FC11 x2 swapped to Nichia 219B 3500K | FW3 CuTi XPL-HI 5000K + 18350 tube | Olight I1R EOS (de-anodized) | Convoy S2+ 7135x8 T6-3B | SkyLumen LEPvn | HDS Rotary Nichia 219B 4000K | Nitecore Cu TINI | Fraz Labs Tiny Tank 18350 | TnC Aluminum Deep Red
Jack Kellar
Jack Kellar's picture
Last seen: 23 hours 45 min ago
A tub of o-ring-friendly silicone grease. Immediately picked up an old toothbrush and went at it on the threads of all my older lights. Convoy S2, Thrunite Ti3, Lumintop Tool, you name it. It’s insane how smooth and nice the threads feel now, some are even smoother than they were out of the box Love No more squeakers either.
Lightbringer
Lightbringer's picture
Last seen: 6 sec ago
Yep, that’s why (as long as I’m motivated enough), I’ll scrub down even “well-lubed threads” and even pull off and clean O-rings and the grooves they sit in, and relube everything from scratch. Buttery smooth…
People forget that even the aforementioned “well-lubed threads” is they they’ve just been machined and anodised, and can have leftover grit, etc. embedded in them and in the lube. And it just wears with each unscrewing/rescrewing. Scrubbing-down and relubing gets rid of it.
That’s why sometimes squeaky unlubed threads can be better, as it forces you to do that (or just live with grindy threads).
Jack Kellar
+1 to you Thumbs Up Next time I go on a re-lubing spree, I will remove the o-rings to give them a very good slather. The TN12 I gave to my brother sure could use that treatment after more than 5 years of use.
Bwana
Last seen: 31 min 13 sec ago
I got my tires rotated at a Mavis tire center. Found a free coupon on their web site . During the rotation they inspected my 2012 MDX with 57,000 miles and said my tires needed replacement (It’s a second set with 20,000 miles on them). They also claimed my rear shocks were leaking oil into the cylinders (whatever that means), and I should replace the front struts at the same time . Oh and I would need an alignment to go along with the shock and strut change .
Lightbringer
Wow. Were you wearing a teeshirt that said “The Muggle” on it?? LOL
BOO5TED
BOO5TED's picture
Last seen: 14 hours 24 min ago
How often are you rotating the tires? If not every 5K they will definitely wear prematurely. Recommended mileage for shock/strut replacement is 50k (according to Monroe who makes 90% of the shocks/struts out there) so that sounds about right. The camber/caster adjustment on the front will need to be reset if you changed the front struts because the adjustment bolts are what hold the struts to the spindles.
Is it common for them to be leaking @ 57k? No, but it’s not unheard of. I work for a tire retailer/service center also and I see situations like yours everyday. Most people do not do the standard recommended maintenance on their vehicles and are surprised when they see the service bills.
Just remember that maintenance is always cheaper than repair.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
Bwana
I generally rotate my tires every 5000 miles when I do an oil change . But at age 70 the MDX wheels and tires are getting a bit unmanageable .
I wasn’t always a car muggle (I really hate that word) but since they added all the damn computers and such there aren’t too many things I can do myself .
Oil change , tire rotation , change tranny fluid , spark plugs , simple stuff.
Geuzzz
Geuzzz's picture
Last seen: 12 min 43 sec ago
Sirius9
Sirius9's picture
Last seen: 7 min 52 sec ago
NeutralFan wrote:
raccoon city wrote:
Scorpion!
That’s pretty scary raccoon city!
I thought that raccoons eat scorpions! Big Smile
cohoer
Last seen: 1 hour 28 min ago
Spark plugs? I’ve got a handed down Toyota Matrix with over 200K miles with the same plugs and even the same clutch. They sure don’t make ‘em like they used to. (thank God)
JaredM
JaredM's picture
Last seen: 16 min 58 sec ago
Ahhh Yes. The old 1zz-fe. I knew that engine well.. consuming lots of oil ?
djozz
djozz's picture
Last seen: 1 hour 35 min ago
14 AWG silicon wire, and 34AWG teflon wire: that stuff is much more tiny than I expected. From Hobbyking.
Jack Kellar
A Lii-100 charger. I was intending to give it to my brother, but he stayed with my older battle-tested one that I’d loaned to him.
thefreeman
thefreeman's picture
Last seen: 13 min 32 sec ago
Do you think it will work well for aux led/switch connection ? I assume that at this low section it must be flexible enough even if it’s teflon ?
How fast is the shipping from EU stock ? (if that’s what you chose).
djozz
djozz's picture
I ordered on nov3, so 9 days ago, indeed from EU warehouse.
The teflon wire at this thin size is very flexible of course. Can not tell you yet how it is to work with it other than that I can conveniently strip the end between my teeth. But I agree it is probably handy stuff for aux led and switch connections. And correction: I see now that it is 36AWG, remembered it wrong.
thefreeman
Alright sounds good, thanks, it would have been nice with more than 2 colors, or just white, but it will do.
Bak
Bak's picture
Geuzzz wrote:
!{width:70%}https://i.postimg.cc/C5NWWWfr/20201022-132227.jpg!
Very nice. One of my abolute favourite budget knifes Thumbs Up An updated model is on the way according to QSP instagram.. take my money
elbakan1
So some good samaritan illuminated me to the original thread.
I got a Fitorch PT25. Little Fatty.
I really don’t know why I wanted to mention this.
I’ve received more than 100 lights in the last two years.
And nobody knows. Go figure.
Cheers.
Lighting up the world one flashlight at a time.
TimMc
TimMc's picture
Last seen: 3 hours 1 min ago
Emisar D4V2 Sand XPL-HI V2 5D 4000K arrived today! Beer
Josen for young
Josen for young's picture
Last seen: 4 weeks 10 hours ago
Got a new starry light from company. Lol
Wurkkos Directの日本担当メタです。
よろしくお願いします。
コラボなどのお問い合わせ:
beyondyoungmoon@gmail.com
djozz
djozz's picture
Cheers.
People like to tell what they got, and people like to know what others got. For the fun of it. And to justify our addictions of course.
Unheard
Unheard's picture
Last seen: 4 min 23 sec ago
Nice picture, nice light, nice LED choice. Enjoy Thumbs Up
The 5D is my potential excuse to buy another D4V2, for sure again with SS bezel.
OT: I got a new kick pad for my e-set along with a double bass pedal. Now I have to learn playing it LOL
Smile, you cannot kill them all.
