GB BLF LuckySun D80-SE Need long tubes? -3/3/16
2842 posts / 0 new
Chizult
Last seen: 5 years 3 months ago
Streamer wrote:
Those are protected batteries.  They are TOO LONG for the stock D80 BLF and should not work properly.  There is a thread for obtaining a longer “special run” battery tube.   Or you can use unprotected 18650.  It is shorter and should work properly.
ETA:  Any battery 69mm  and less in length should work fine in stock tube.  The length specs on your batteries (68mm) may be wrong as they have the protection circuit built into bottom of battery.  Measure your battery length if you can.
How in the hell are batteries of varying length to the point that they will not work in different things still the same battery?!? Obviously not pissed at you, just the world in general apparently. Any chance on a link to the thread you mentioned, I have no idea how to navigate this website.
ETA: It also kind of pisses me off that there is no information in the description of the light as to which length battery it will take.
ETA2: 68mm is accurate BTW.
will34
will34's picture
Last seen: 1 day 5 hours ago
Most lights have a battery tube designed to fit up to 70mm batteries, but some newer lights only work with unprotected cell under 67mm. It is often confusing for new users because at first it seems like protected and unprotected measure the same. 18650 is the size of the battery and it stands for 18mm diameter, 65mm long and 0 stands for cylindrical. Of course protected cells are way longer than 65mm however they don’t sell it as 18680/18690. Anyways if you can take good care of your batteries, there is no need to use protected cells at all.
Streamer
Streamer's picture
Last seen: 1 year 4 months ago
Chizult wrote:
Streamer wrote:
Those are protected batteries.  They are TOO LONG for the stock D80 BLF and should not work properly.  There is a thread for obtaining a longer "special run" battery tube.   Or you can use unprotected 18650.  It is shorter and should work properly.
ETA:  Any battery <69mm in length should work fine in stock tube.  The length specs on your batteries (68mm) may be wrong as they have the protection circuit built into bottom of battery.  Measure your battery length if you can.
How in the hell are batteries of varying length to the point that they will not work in different things still the same battery?!? Obviously not pissed at you, just the world in general apparently. Any chance on a link to the thread you mentioned, I have no idea how to navigate this website. ETA: It also kind of pisses me off that there is no information in the description of the light as to which length battery it will take. ETA2: 68mm is accurate BTW.
bugsy36
bugsy36's picture
Chizult wrote:
bugsy36 wrote:
Regardless of length......Throw those batteries out!
These are about as inexpensive as they while still being a quality battery from a reputable seller...
http://www.mtnelectronics.com/index.php?route=product/product&path=59_88...
Any decent suggestions on Amazon? I freaking hate paying shipping... Also, I'm willing to put more money into a battery if it gives me longer run time. Charger suggestions?
Even with the $2 shipping you will not get a better price on Amazon plus you do not have to worry about sub-standard or fake batteries
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
robo819
robo819's picture
Last seen: 1 month 1 week ago
In the product description on the amazon page if you look on down they list the cells first as “* Dimensions: 6.8 cm x 1.8 cm x 1.8 cm” then further down they list them as “Product Dimensions 3.1 × 2 × 2 inches” which converts to roughly 78.4mm.
Also there is not an 18650 cell made that will carry over 3500 mAh that I know of so that is warning sign that they are over rated.
Also agree with what bugsy36 said up there….
“Regardless of length……Throw those batteries out!”
And anything you buy from Richard at
http://www.mtnelectronics.com you know will be of good quality and not a fake so it is worth piece of mind even if it cost a couple of dollars extra.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Streamer
Streamer's picture
http://www.budgetlightforum.com/node/36983
see Jan.5th update at above link
Chizult
Thanks all. Unfortunately there seems to be a learning curve with everything these days. I bought the recommended batteries and a charger and am returning the Amazon purchase. For reference, those batteries were under 69mm, so might keep that in mind when recommending for other folks.
kronological
kronological's picture
Last seen: 3 years 4 months ago
It is VERY irritating.
I believe XTAR calls their protected batteries 18700 because of this. They are the only company I know that does this.
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
DEL
DEL's picture
Last seen: 3 years 2 months ago
Got the driver out tonight. This was easy using long-nose pliers with the handles locked open in a drill-press vise.
For those interested in the circuit, it is really simple.
The usual reverse polarity protection diode on the left. From the diode it feeds the MCU on pin 1. The capacitor is for decoupling of the MCU supply voltage. Here it is located after the diode, against BLF wisdom that say it should be before.
The 100k resistor is in parallel with the capacitor. The 30k is across the incoming cell voltage. Not clear, but these probably serve a snubber duty.
The MCU PWM output is on pin 5, which is voltage-divided by the two 15k resistors, before driving the FET gates. In the photo I have bypassed the entry resistor of the divider, marked in green, to drive the FETs with full MCU voltage. Not sure why it was done this way. A 100-220 ohm resistor is more typical in this position. Try at own risk.
I have also moved the black emitter wire to the other side of the 000 pack.
The FETs, prior to modifying the gate drive, had a voltage drop of 130 mV at 4.4 A (30 mohm). The 000 pack had a voltage drop of 32 mV (7 mohm).
After the gate drive modification, the FETs had a voltage drop of 80 mV at 4.5 A (18 mohm).
Voltage drops are the RMS values calculated by an oscilloscope and were also visually confirmed on the ‘scope.
Putting everything back together, a fresh 30Q now gives 3.65 A. Before modifications it gave 3.20 A.
Both values are on a cold light (a LED on DD will draw more current as it heats up).
Again, I am not chasing amps. I will upgrade to a FET+1 driver, but for UI reasons (and to get efficient low modes). This was done just out of curiosity.
dudunphy
dudunphy's picture
Finally got mine ordered! I only get paid once a month and I was waiting for the 5a to come available. Party I’m gearing up to post in the collection thread. Big Smile
Dustin
MRsDNF
MRsDNF's picture
Last seen: 4 days 18 hours ago
Nice work DEL and explanation sharpie not that I understood any of it.Smile
MRsDNF
MRsDNF's picture
Nice work DEL and explanation Sharpie not that I understood any of it.Smile
DB Custom
DB Custom's picture
Last seen: 1 day 14 hours ago
Interesting. Way back in post 2077 I stated that bypassing the 4 “000” resistors netted the most gain. I had the light doing 5.11A at that point. So I guess y’all worked your way back around to that fact by moving the negative lead to the other side of that bank. The 5.11A was also with a spring bypass in the tail. Changing the FET’s to my Vishay variants really made no difference, although they’re top FET’s hand picked for 15mm and 10mm driver builds. Good that we get to the same place taking different routes.
Wish I knew all the how’s and why’s, would probably have forgotten already anyway even if I did. Wink
kronological
Sharpie wrote:
DB Custom wrote:
Interesting. Way back in post 2077 I stated that bypassing the 4 “000” resistors netted the most gain. I had the light doing 5.11A at that point. So I guess y’all worked your way back around to that fact by moving the negative lead to the other side of that bank. The 5.11A was also with a spring bypass in the tail. Changing the FET’s to my Vishay variants really made no difference, although they’re top FET’s hand picked for 15mm and 10mm driver builds. Good that we get to the same place taking different routes. Wish I knew all the how’s and why’s, would probably have forgotten already anyway even if I did. Wink
Sorry Dale, but that’s not what Del has described at all. I think you may have been chasing your own tail. :~
Eliminating the zero ohm resistors make only a tiny difference, 7 milliohms. Moving the wire was just a more elegant way of doing it.
On his copy there is a different resistor that seems to be far too high a value.
The effect is to nearly halve the PWM drive voltage to the gates of the FETs.
Which I had speculated might already be an issue, when the cell drops to about 3 volts.
By shorting it out he has returned the gate voltage to where it ought to be.
He has shown that this improves the drive voltage enough to halve the resistance of the FETs, which is tremendous.
I guess that he did his measurements at near maximum supply voltage.
The difference should be even more dramatic at lower supply voltages.
Nevertheless, the FETs were still working respectably, even when only being driven with no more than about 1.8 volts at the gate, which frankly amazes me.
Now it needs someone to corroborate his findings by measuring the resistor in question.
Over you you Dale, rescue those drivers from the bin and measure the resistors on them. The prototype samples, then the production one.
If the production drivers were assembled in one run, there is every chance that they are all the same as Del’s.
So it is all about the voltage drop across the driver. Every milliohm increase drops about another four millivolts. And that is enough to drop the LED current dramatically.
With Del’s mod, the driver seems rock solid to me.
I hope this explanation will be confirmed.
Sharpie, does this mean a bad resistor could be the culprit? Perhaps mislabeled…not really ‘000’?
My Reviews: Ma
DEL
DEL's picture
For info:
My tests were at 4.2 V. I measured 1.9 V drive at the FET gates before the modification.
I did not bother to test with lower voltages.
I did check the diode. It is a Schottky (Vf = 0.25 V).
In post 2048 OscarM posted good quality photos that also show two 15k resistors.
OscarM wrote:
This is how my driver looks, not sure if it looks different to any other drivers?
DEL
DEL's picture
The FETs seems to be Alpha and Omega model AO3400 (or some clone thereof).
Datasheet: http://www.100y.com.tw/pdf_file/ALPHA_AO3400.pdf
From the datasheet:
Interesting graphs:
With the stock driver, we are at Vgs = 2V with a fresh cell.
So if this is indeed our FET, that 1st 15k resistor has to go.
emarkd
emarkd's picture
I told myself I was going to leave this driver alone, but, well, you know…
So I broke it open and did the two mods listed above. I moved the negative emitter wire to the other side of the resistor bank, right next to the FETs. I also pulled that first 15k resistor and solder-bridged it. Here’s a crappy cell phone shot of the aftermath:
(The other 15k resistor was straighter that that before I started. Works though, so I left it crooked)
This was a super simple mod to do. Anyone with a soldering iron can do it. My results?
mod Amps (tailcap) candela Throw
Stock 3.5 28,100 335
Tailspring replaced/bypassed ? 28,700 339
Driver mods 3.9 32,300 359
All testing done with Samsung 30Q cell. I think those are some pretty good performance numbers from such a small light. I really like this one!
It should be pointed out that I think my dmm reads low. I need to build better testing leads. So don’t focus so much on the hard numbers as much as the change. From a stock light, by bypassing the tailspring and doing the two driver mods, I’ve increased my throw by about 7%. Of course heat builds up quite a bit faster than before too. I also poked around on my driver a bit and everything there read like it was supposed to – no mislabeled resistors or anything like was speculated earlier.
DB Custom
DB Custom's picture
To the LAB! Smile
I put the production driver back in, with the changes I’d already made (bridged bank of sense resistors, new mosfets) and measured it both for current and in the lightbox (simultaneously read)…
4.83A for 1431.75 lumens
Then I pulled it back out, removed that 15K resistor and put an 100 Ohm Vishay resistor in it’s place, re-assembled and tested again with a new cell.
4.86A for 1393.8 lumens
I really don’t see that the recommended change is actually benefiting anything.
emarkd
emarkd's picture
DB Custom wrote:
To the LAB! Smile
Well that’s interesting. Wonder how I can see almost half an amp of gain by bridging those pads and you see almost nothing. Could it be because you swapped your FETs? I don’t claim to understand the electronics theory as well as the rest of you guys, but I’m definitely seeing an increase in performance over here.
DB Custom
DB Custom's picture
I don’t know the electronics either, I grew up in a lumber yard, an now a photographer, pretty much scared of electricity truth be told.
I know that the Vishay mosfet’s I put on the driver are the best that can be found. Wight backed me on that as have others. Wight is the one that told me what to look for in the spec sheets. When I added these, the difference was negligible. I got the most gain when I bridged the sense resistor bank.
And for what it’s worth, this driver is exactly as those pictured, 153 pair of resistors, 4 “000” sense resistors, and it had the A009T Mosfets. The spec sheets on my Vishay componenets show lower Rds On, but not by a whole lot. I used Vishay SOT-23 Si2312CDS, a side by side pair right out of the tape.
kronological
emarkd.
I believe, if I am understanding Dale correctly, that the ‘000’ resistors were already bridged.
The only change is replacing the 15K resistor (recommended by Sharpie and Del), which had almost no difference. Therefore, the 15K resistor is not the culprit either.
Dale…please correct me if I am wrong.
My Reviews: Ma
emarkd
emarkd's picture
I shoulda known better than to make two changes before testing. That’s just bad science, no matter how you look at it. I can fix it though. Smile I don’t want to fool around with trying to put that little smd resistor back in place, but moving that ground wire back to the other side of the resistor bank is easy enough. So I cracked my light back open and did just that. My results: 3.92 amps at the tailcap.
In other words, on my light, on my workbench, on my meter, I got zero gain by moving that ground wire (equal to bridging that resistor bank) and almost half an amp of gain by replacing that 15k resistor with a solder bridge.
I can’t believe I’m carrying on with this — I swear I’m not trying to argue with Dale about flashlight modding. The guy probably forgot more about flashlights while eating breakfast this morning than I’ve ever known and I have the utmost respect for him and you both Krono, but I’m just not seeing the same results. Again, I don’t claim to understand it, I’m just reporting what I see.
AndreasTPC
I got my D80 today, I plopped a battery into it and turned it on. It didn’t work. I did the usual paperclip test, and got some light, so that narrowed the problem down to the tail cap. While I was visually inspecting the tailcap the entire contents of the tailcap fell out into my hand. I figured the retaining ring must not have been screwed in properly. While the tailcap was disassembled I took the oppertunity to clean off all contact points in there using isopropyl alcohol, lube the threads, and put it back together, screwing in the retaining ring properly this time.
I screwed on the tailcap on the body, turned it on, and the flashlight worked. However as I was screwing on the tailcap I heard a popping sound. When I unscrewed it again the retaining ring had came off it’s thread and the tailcap components fell out again. I’ve repeated this process twice more. It only happens when screwing it on with a battery inside. It appears that when I screw the tailcap on the pressure from the battery somehow manages to push the retaining ring loose. I’m not using excessive force when screwing it on. I was using a protected battery, 68mm long. I ordered some unprotected 30Qs around the same time that haven’t arrived yet, so hopefully when I get a shorter one the pressure will be less and the problem will be gone.
But still, what should I do about this? Just live with it and hope the shorter battery works? Try to get a new tailcap from gearbest? If the later, how would I go about doing that?
DB Custom
DB Custom's picture
Survey says, it’s the emitter.
I pulled the brass post on the driver, put a solder blob on it and checked it. Marginal gain. So I wired the emitter, in the light, direct drive to the 35A cell. 4.99A. There’s just not much there to be gained if I was getting 4.83A to 4.86A from the driver. This is top end, pure and simple.
So, I pulled an old XM-L2 off an Aluminum star and put it on a SinkPad, put that in this light and put the brass button back on the driver. Bingo! 5.52A in the light. Same driver, same cell, different emitter.
Edit: Oh yeah, the funny thing. The older emitter pulls 5.52A but only makes 1383.45 lumens. So, we were getting top lumens with lower current draw… higher efficiency all along. Funny, huh? We get all caught up chasing the current when the output is right there in front of us all along.
EditII: I did check direct drive with the Star in the light, it hit 6.11A but wasn’t being pressed down against the emitter shelf with no reflector in place, it started to get hot. But that tells me the driver in sheer top end with this old emitter is costing some half an amp, might be in the 22ga wires on the driver or just running through the circuitry, don’t know. (test leads I used were 20 ga. but about 4” long each.) Still, it’s fully capable of making the power given an emitter that will take it. Maybe I’ll check it powering a triple or the SBT-70…
DEL
DEL's picture
kronological wrote:
emarkd. I believe, if I am understanding Dale correctly, that the '000' resistors were already bridged. The only change is replacing the 15K resistor (recommended by Sharpie and Del), which had almost no difference. Therefore, the 15K resistor is not the culprit either. Dale...please correct me if I am wrong.
Hi kronos, Dale,
We are still obviously missing something. Problem is we are talking about milli-ohms here and there, it does not take much to move the readings around when driving a diode with voltage source (as opposed to a current source).
Regarding the 15k resistor:
Looking again at the datasheet of the AO3400 FET (this may not be the FETs we actually have, but the numbers are quite typical), we want the 'on' resistance of the FET to be a low as possible. For this we need the FET gate voltage as high as possible. This why only some FETs are suitable for DD drivers - we have limited voltage available.
With the stock driver, best case (FET not heated), we are operating between the two orange dots, gate voltage at 2 V and down to 1.5 V with the cell drained. We are off the trend line, the purple is just my (optimistic) interpolation.
Bypassing the 1st 15k gets us to operate between the two green dots, 4 V to 3 V.
It can only help.
DEL
DEL's picture
Dale, do you normally wait for the LED to heat up when taking a current reading?
I tend to take it as fast as possible before the cell sags or when the mcpcb is floating. But I know the LED Vf will go down as it heats, pulling more current. Another variable not everyone is considering.
I agree with you chasing amps is somewhat futile. It is like tuning your car for maximum fuel consumption.
At the end of the day we should be measuring lumens.
Even measuring watts is better than measuring amps, W = V x I. Higher Vf lowers the current draw we can get from a single cell, but it does increase watts (and hopefully lumens) at the same time.
ada_potato
Last seen: 1 year 3 weeks ago
Andreas,
-Sorry, can’t help you, but I got 3 D80’s yesterday and I have the same issue. I was using old 2400mah protected Trustfires, I thought may work to try the light out. I have unprotected cells that are in the mail, I’ve given up until they arrive. I won’t know until then if I’ll need the longer tubes mentioned in this thread.
DB Custom
DB Custom's picture
I take the reading at start, if I take a delayed reading I also report that.
I went back to the bench and soldered a loop between the driver neg and Star, with the light assembled and no spring bypass it ran 4.67A through this new (old) emitter. (At the emitter) With the spring bypassed, it runs 5.21A at the emitter on a 35A. This is with my Vishay MOSFET’s on the driver and the resistor bank bridged and with the 100 ohm resistor in place of the 15K.
DEL
DEL's picture
Thanks Dale. Also good info on the spring bypass. It is impressive how the steel springs heat up once you get to 5+ A. Not healthy for the switch or the cell. I was doing it with a power supply in constant current mode, in a light it probably self-regulates a little as the spring heats up and its resistance increases.
Re. The brass button and related driver pcb vias, I measured 7 mV across it while running 4.4 A. So as you said, not significant.
kowshak
A lot of blood, sweat, tears, care and attention has gone into making it and its a shame that the numbers don’t match the prototype’s, but it’s still a nice bright light and can be modified to hit the numbers without a whole lot of effort Smile
Mine has arrived and the fit and finish are nice! I’ve only been able to measure around 2 amps at the tail end with a cheap multi-meter. With better / unprotected cells and better meter leads I may see more.
