D.I.Y. Illuminated tailcap
1813 posts / 0 new
tristanxoxo
Last seen: 5 months 1 day ago
pilotdog68 wrote:
I was unaware the 5.1x did not fit the small omten, it was designed to. Probably Oshpark didn’t cut exactly where I wanted. The “Big Ring” version you linked will definitely fit over the switch, it will probably be even too sloppy. It might be too big around the outside too, so check the diameter of the washer that comes stock.
Rev5.1 for 14mm is the one I use the most and it has no issues with the small omten.
Thanks for your reply pilotdog. The S2 does not use the small omten like the S2+. It uses the larger one in the link here.
pilotdog68
pilotdog68's picture
Hmmm i was not aware. Do you have calipers to measure the width of the post the hole has to go around? That might be the one matt had when he asked for the larger version
tristanxoxo
I will borrow a pair and report back. BTW, thank you so much. I did the tailcaps for my S2+ lights and I love them!
pilotdog68
Also, if it’s close to fitting, you might be able to just drill out the middle a little. The Rev5.1x doesn’t have any hidden traces in the middle I don’t think
J-Dub74
J-Dub74's picture
Has anyone had a chance to try out one of the new clear gaskets Simon made for the S2+ yet? He was hoping for some feedback. I would think djozz may have received them by now but I’m not sure. I sent out a few handfuls and I’m still sitting on a pile of them that I need to send to Richard. Blushing
djozz
djozz's picture
Last seen: 4 days 12 hours ago
I have not received them yet, there are still (probably, but I can’t see them) 6 red leds shining against the (still) black gasket in my red S2+.
emarkd
emarkd's picture
Crap, I can’t believe I haven’t tried those yet. End-of-the-year school stuff has had me very busy with all these kids. I’ll try and get that done this weekend and report back. Sorry :/
pilotdog68
Well…. I was waiting for what other people think, but I ended up not using them. They obviously allow more light through than the black and I’m grateful Simon made the switch.
But, they still block more light than a nylon glove, and I couldn’t get the retaining ring to screw down because of the thickness
juaquin
Last seen: 2 years 11 months ago
Same here, got maybe 3/4 of a turn. I ordered 0.8mm boards to solve that; got the switch boards today and waiting for the ring boards. They should fit better. Still can’t figure out a good bleeder/tailcap combination (with decent current) that doesn’t mess up the modes, though. Need ~10ma to get a nicely visible red light on an S2+.
juaquin
Not much to report, they work as expected. I’m having issues with the switch stack being too thick and my driver modes not working correctly, but the clear gaskets aren’t part of those problems. As far as I can tell they are exactly the same as the black ones. They work fine but you need decent current to get it visible – 10ma with red LEDs looked good to me while testing (would be less with other colors). Would be nice if the gaskets were totally clear but the current ones are much better than the stock black gaskets and definitely usable.
JamesB
This thread is pure win, thx Pilotdog68 and contributors, i realized i need an amber gold lighted tailcap on my beside table torch more than anything in the world.
djozz
djozz's picture
I finally got the clear gaskets in the mailbox, and more than I ould ever expect: 140!
I put one in my red S2+ and can finally see the red tail light! Smile The light has the driver scavenged from my blf-x5 so the driver timing is prepared for the lighted tail. I used the same tail resistance as the blf-x5/6 to retain normal driver performance, but with 6 red leds. Nevertheless it draws only 0.78mA. So the leds are pretty dim and the metal tailcap does not help with that: works as a dim locator light for use at night, but nothing spectacular. I will swap the resistor to get to 5mA and a bit more light (and 10 days runtime on a fresh 18500 cell). For now:
J-Dub74
J-Dub74's picture
!https://c7.staticflickr.com/8/7233/27187954006_c6e2c4a915_b.jpg!
Excellent! Grad Thanks for the quick feedback djozz. I know it takes more power to see that glow in the S2+ because of the switch design but I’m happy that it works. It was a pretty simple change so it just seemed like an easy thing to ask Simon to do to help accommodate. If anyone encounters a problem with the function of the clear switch seals please let me know.
djozz
djozz's picture
These clear gaskets were send to me to be distributed among BLF-members from Europe who have black gaskets in their S2+ lights and would like clear ones for building a lighted tailcap. (as I understand, Simon will use the clear ones for all new S2+ hosts that he will sell)
Now that I have so many, I do not think I will ever get rid of them, and because it is no more expensive to send them worldwide than it is to send them inside the EU, I will send them everywhere for shipping costs plus envelope (€1.50 worldwide).
(PM me with your address and your reasonable number of gaskets, I will reply with my Paypal)
djozz
djozz's picture
The rings in this sheet of silicon are much larger than the black gaskets that is to be swapped. But you can rip off the center and outer part and be left with the exact gasket as the black one. So I had no problems with the swap.
(I used the 16mm 6 led lighted ring with a thin cardboard ring around the ring of leds to prevent shorts with the tail-section, even though it is anodised on the inside)
J-Dub74
J-Dub74's picture
Now that what I call paying forward! Smile Very cool of you. I still have a handful as well but only for US residents as shipping outside the US is just ridiculous so this is an excellent option for non US residents. A tip of the hat to you. Hat
Cheers
T18
Last seen: 3 years 1 month ago
Just wanted to drop you a note PD that I have followed your builds here or where ever I’ve found your info going back to the early build for the Krono’s project.
I always thought that lighted tail switch in the X6 ×5 was so fantastic and I’ve tried repeatedly to follow your simple directions and all I get is failures mostly I think do to shaky hand old guy syndrome,
However the reason I wanted to say something to you is because I was one of those knuckleheads that got involved in that stupid CPFItalia Cometa thing and bought two of those dangerous lights, but sitting here one night looking at that darn light it dawned on me that they had your new revision dual Blue LED switch so immediately swapped it into the Kronos and wow, now that box set is absolutely perfect, those switches look so good compared to the original single led switch, so anyhow, if anything I justified my buying those two stupid Cometa junk lights and decided I just paid $40 each for your new switch and feel alright about that.. Ha
I’ll keep trying to build them but since BG has them I sure wish they’d put them out for sale since I’d buy a half dozen to go in all my alums also. So thanks for all your amazing work PD..!!
pilotdog68
Thanks for the comment T18. I had seen it in one of the Cometa threads but thanks for posting here too. I’m glad they brought a silver lining to your Cometa experience
mattlward
mattlward's picture
Last seen: 3 days 12 hours ago
Hey PD, have you told T18 about the embossing tool soldering station? That is a huge help if hand soldering is difficult!
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
pilotdog68
Is that what you use matt? I still use mine. I was considering getting a proper rework station, but I’m not building as much as I used to.
mattlward
mattlward's picture
Yup, still use it… I am having the same thought. I would like to be able to change 1 component at a time and that is almost an all or nothing tool I have also thought about adding a fan speed control to it as well and forging on… I like the looks of the station that can be modded for better control. Have built a bunch of stuff with it and it just keeps going!
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
pilotdog68
On mine the air inlets are all on the end. Sometimes I cover up half of them with my hand and that slows the air speed down. It also makes the temps go up, which can be useful but you have to be careful it doesn’t start to melt from the inside out.
T18
You bet PD, and yes had to really look hard for that silver lining but once discovered I was literally thrilled, I don’t know how I can go so goofy over a couple switches but certainly did, and after the swap sat here with the lights out and switches on and just enjoyed ha ha ha
Thanks for the mention Matt regarding a embossing tool soldering station,
I think I get what your referring to, sort of a rework station, surface mount work, heat gun etc, frying pan.
If you happen to have a link and the time I’d sure appreciate a point in the direction,
I believe the rework station I saw was at a place called All Spec, not positive if I’m thinking down the correct lines here.
Anyhow, no wonder Simon wouldn’t sell me a few metal S2+ switches a few months ago, I sure haven’t been keeping up and just noticed the S2 work, wow, they sure do look good,
Simon’s next release will probably be sporting some really nice upgrades, the S2S+1
mattlward
mattlward's picture
My reflow iron… search for DARICE EMBOSSING MULTI-PURPOSE HEAT TOOL, 320 WATT NEW on ebay…
Don’t laugh to loud, works great! Thanks PD!
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
T18
Thanks Matt, I was just looking at some rework stations, and a lot of accessories that I have no clue about, like assorted little cups that appear to go over the part and hot air heats the part up and melts the solder or so it seems, So laugh at you Matt.? Now that’s funny,
I have a lot to learn yet and really glad you mentioned this,
I’ll take a look at this one in the morning,
All I need is a decent beginners station, maybe something that can be upgraded as my skills improve, don’t know.
Thank You Matt..
nofear87
Last seen: 11 months 1 week ago
I build a nichia light today with nanjg 105c and nlite firmware. I used Rev 5.1 LTC board. Lightning works fine…but when I tap I cant switch modes. The main emitter shut down when I tap. I didn’t use a bleeder and no resistor on the ltc board, just 2 leds in parallel with a bridged R1 spot. Maybe this problem is known and somebody can help?
Thank you!
Edit: I found another interesting detail…when I use a battery with voltage < 3,9V it works. >4V did’nt work. What do you think?
pilotdog68
sounds like the MCU is never shutting down. Try a bleeder.
Nicolicous
Nicolicous's picture
Last seen: 1 year 8 months ago
Finally i got all the parts and gave myself a crack modding.
the resisters and SMD are tinny and it hurts my eye welding.
Destroyed 2 LEDs while over welding and lost 2 resistors dropped on ground but successfully put together.
http://imgur.com/xEfICOJ
http://imgur.com/x5dCieZ
Nico -.-
djozz
djozz's picture
Looking good! Well done. Smile
nofear87
why do you think a bleeder could help?
