GROUP BUY IS ACTIVE TO ANYBODY THAT WANTS TO JOIN.
The discount code is GBLFA6SE
This is the Banggood page where you can purchase the BLF A6.
Production is in high gear until interest slows and then that will be all they make. Buy them while they are available!
***For those interested in an unanodized version see ToyKeeper's thread HERE
***For those interested in shortened tubes for 18350 see RemanG's thread HERE
***For those that need assistance with troubleshooting and fixes you can also look HERE
*** All updates to OP are at the end of this post but ABOVE the interest list.
I like easy to carry tube lights. One of my favorites is the new model designated the A6 and comes with a an XPL emitter, 2.8A 4-mode driver. The BLF version of the A6 is here or use this link - http://www.banggood.com/BLF-A6-CREE-XPL-1600LM-7-4modes-EDC-LED-Flashlight-p-991823.html
What I am proposing, if it can be done, is to have Banggood manufacture us a BLF Edition with a A17DD-SO8 driver
(designed by our own Wight). The idea behind using that driver is that it can drop right in because it is single-sided and we can eliminate the moon vs amps debate as well as it will give the many the ability to change mode levels to suit.
Proposed specs (see below for final specs and price)
- XPL emitter in CW and NW tint
- Copper mcpcb
- A17DD-SO8 driver (already approved by wight) Now the A17DD-SO8 driver +1 7135 driver
- 7 modes with stepdown at high (no blinky) and of course the lowest possible low
- AR Glass (I remember reading that it already comes with it but I cannot find that reference again)
- BLF-SE engraving (subject to Kronos' approval)
- Guessing that approximate cost would be $22-$23
Unfortunately to pull this off would not be quite as easy as it sounds. In order to achieve this we would need:
- Quantity of 200 to get the engraving (probably not so hard)
- Quantity of 500 to get the copper without increasing cost (500 is the minimum run Maxtoch will do for mcpcb and if true to form this unit should have 16mm mcpcb). Less is possible but cost will increase.
My math that inspired me to attempt this group buy:
BLF 17DD Diver from RMM w/ options ~$14.25
Noctigon 16mm Driver from RMM ~$1.99
Subtotal parts 16.24 plus shipping plus cost of flashlight (EE A6 ~$19) = $35.24 +/- vs GB of $22-$23 (or even less if we can get the same success of the X6-SE)
To me that is a huge savings.
UPDATES:
12/31/14: Was informed that EE WILL indeed use the A17DD-SO8 driver if we can get enough interest to move this thing forward. Also have lights on the way to test with the A17DD-SO8 driver so everybody can see what the driver truly is capable of. FYI - I know it sounds like I am hyping this driver but I would not be so excited about this driver of I did not think it or see that it was capable.
1/6/15: Stock lights are on the way to be modified with Wight's driver so that this light/driver combination can be tested and demonstrated. The actual production run (light and driver) will be by EE Manker. The A17DD-SO8 driver will not be manufactured for sale separately nor does anybody have permission to do so except by individuals for personal use. (The A17DD-SO8 driver will be available in the future from RMM's store: http://www.mtnelectronics.com/)
I would really like to know if this is possible and if there is any interest please post here.
1/7/15: There are 4 main things that separate this from a stock Eagle Eye A6
- BLF Logo
- The A17DD-SO8 driver
- Copper for the emitter
- User's ability to flash firmware
1/20/15: Samples arriving. Preliminary results are good. See post #304 and beyond for DBCstm's tests. The below numbers are with no spring bypasses, just the A17DD-SO8 driver and copper star.
Stock numbers with factory driver
Numbers with A17DD-SO8 driver over 5 amps!! (Post# 326)
1/26/15: I have been working like crazy so I did not have the opportunity to swap the driver and the emitter in my sample until tonight.
Wow! Even with a laptop pull this light blows everything away!!Throw a 25R in there and this thing shoots the moon
The beam profile, even though it is subjective to the individual, is fantastic. Not a flood but definitely a large spot with a nice spill. Sort of what I would like to see possible but not with a triple. It is not a thrower like the LS D80 Kronos is working on but I never expected it to be either. I can still light things up several houses away
The Xiaozhi styled tube/barrel feels real good in the hand and something else that is welcomed is the deep scallops that allow you to get to the switch (sometimes I have to wear heavier mechanics gloves at work vs surgical styled gloves)...and this thing still tail stands.
The driver, as it is and I requested be setup at the moment, has 7 nicely spaced levels that run from the lowest low (battery dependent) to all out (again battery dependent). You can refer to the OP for the link to Dale's numbers. I have yet had the opportunity to take my measurements but just by the output visible to the eye Dale's numbers are spot on.
Where we currently stand on progress is as follows:
- Waiting on samples for others (aside from Dale and myself) that got tied up in shipping
- Have another person on the team that is experimenting with code and UI's and attempting to get the most reliable low (or moon) possible
- When the UI is finalized by the team we will ask Banggood to manufacture samples there and send them (they have a holiday coming so things will get slow on communication)
Everything so far is going as planned and expected and very well may end being not only a great light in BLF tradition but also the most versatile light available. Many many thanks to the team working hard on this behind the scenes, and of course all BLF'ers for the support!
2/2/15: 303 units!!!
As mentioned before, the review team is working on the A17DD-SO8+1 7135 driver and its firmware and it is sounding very promising After PM'ing with Banggood tonight we can all expect to see production samples after the Chinese holiday.
2/22/15: The waiting for the holiday to finish is killing me. LOL. I am not sure if everyone in China returns to work on the 23rd or the 27th.
Right now we are up to 382 units. I really do not think getting to the 500 is going to be an issue and I feel real confident in that. If the driver with the +1 7135 can be manufactured without any issue, and the production samples are as expected/required, this GB should start to move a bit quicker.
Thanks to everybody for their patience!
3/12/15: Driver files, firmware, and parts list are in the hands of EE. I am assuming that they need to source parts and speak with a driver manufacturer.
3/18/15: Spoke with Banggood about status for production samples. EE still trying to work out logistics of manufacturing the driver.
3/30/15: Received a pm today/last night from Banggood. Driver has been built by Eagle Eye (I believe it is the +1 7135) but they have some questions. Not sure as to what the questions are but hope that they are questions that the group (less Wight at the moment ) can answer. Hopefully we will have more info ASAP but at least it looks good that Eagle Eye and Banggood are actually working on it.
5/15/15: Samples have arrived! At the moment they are en-route to Dale for further scrutiny....and then to the rest of the group.
What can I say. It is bright as hell! Wight's +1 7135 driver seems to be working great (as manufactured by them). TK's UI is great too. These samples are with the UI that requires soldering the bottom star for memory. I did not solder mine before I sent it of. Therefore it starts on moon every time. All of you moon lovers will be happy to know that at first I thought the light was not working. I think many will be happy with how low this thing can get. Definitely no burning of any pocket. LOL. I also think that many may go for TK's 4-mode option, unless they use the modes to compensate for battery drain (which I often do at work). Another cool thing for you 2-mode people is that with TK's back up feature it is easy to go from Moon to High without all of the modes
That is all from me. You all will have to wait until this weekend to hear from Dale (if he is available), and the remainder of the group will have theirs next week.
The steps are small but the motion is forward. Everybody's patience is greatly appreciated!
As soon as we hear more news it will be posted here immediately
5/25/15: Below you will see the description of the fantastic UI by ToyKeeper
BLF EE A6 firmware (Click HERE for more detail)
The interface is as follows:
(see blf-a6-ui.png for a quick start)
While off:
- Fully click and release to turn the light on. It will go to the first mode or the last-used mode, depending on whether you enabled mode memory.
While on:
- Short tap: Do a short (less than 0.5s) half-press to go forward to the next mode.
- Med tap: Do a medium (0.5s to 1.5s) half-press to go backward to the previous mode.
- Long tap: Do a long (longer than 1.5s) half-press to reset to the first mode (if mode memory is turned off).
- Or fully click and release to turn the light off.
Hidden modes:
- Go backward from moon to access the hidden modes. They are, in order:
- Turbo (just like the regular turbo)
- Tactical strobe (10 Hz)
(or 2-level stutter beacon, if compiled with that option)
- Battery check / beacon mode
(each blink represents about 25% of a full charge)
Configuration options:
- Ground pin 3 of the MCU to enable mode memory. This can often be done by soldering a star on the spring side of the
driver, if your driver supports that. Otherwise, it's pretty easy to make a solder bridge from pin 3 (mode mem toggle) to pin 4
(ground). Or even just wedge a piece of metal between the two pins.
- Short tap rapidly a bunch of times (15+ taps, or until the light stops turning on) to enter soft config mode.
With the default build, this only has one option (mode group), and it will toggle that option each time config mode is entered. It will then
blink, pause, and return to regular operation with the new settings.
Or if you rebuild the source and enable more than one soft config option, the way it works is the light will blink twice for each
option. Turn the light off between the two blinks to toggle that option. The options are whichever ones you enable.
The available options are:
- Mode group: 7 modes or 4 modes:
Group 1: moon, low, med1, med2, high1, high2, turbo Group 2: low, med, high, turbo
- Mode memory toggle (disabled in default build, use pin 3 instead)
Other details to note:
- Low-voltage protection will progressively step down the output at
about 2.8V, and the light will shut itself off when it gets below 2.7V.
- The default turbo step-down is 30 seconds.
- When turbo steps down to high, a short tap will push it back up to turbo or a medium tap will step down further, *even if you got to turbo
by going backward from moon*. The step-down effectively moves it from the "hidden" turbo back to the non-hidden turbo.
- A short tap from any hidden mode will return to the lowest mode.
Compared to other commercially-available lights (especially budget lights), this light is unique or groundbreaking in several ways:
- First BLF light with our own custom driver.
- First BLF light with our own custom firmware.
- First special-edition with a direct-drive FET, so it has the brightest turbo mode you can get.
- First special-edition with a regulated lower-power second channel for stable and efficient low modes.
- True moon mode.
- Up to 1600 lumens from a single emitter in a small tube light (with the right battery, and a spring bypass mod). Closer to 1200-1300
lumens with no mods and lower-amp batteries.
- User-toggle-able mode memory.
- User-toggle-able mode groups.
- Well-spaced visually-linear output modes.
- Includes some hidden modes for those who want them.
- Battery check mode!
- First clicky-switch stock light with both forward and backward mode navigation in a single tap (short/medium press).
- With mode memory off, the user can access 4 different modes (including the highest and lowest) within 1 second.
- Fast PWM so the pulsing won't be visible.
- The firmware and the driver designs are available for anyone who wants to modify them.
6/15/15:
Here is the update til now.
- Looking at 2 manufacturers for this light. EE and brand X
- Trying to come up with clip for light. EE may be able to use X6 tube with clip and brand X is looking to see if deep carry clip can be made.
- EE had better driver with single FET but problems on low mode. We think we know why and new samples have been made where if I understand correctly this time they have used Wight's schematic exactly. Banggood will be contacting EE to get the samples.
- Brand X sent samples with different drivers. We did not like those drivers because Dale's tests show inefficiency where there are greater amps but fewer lumens. Allegedly new drivers are being manufactured so we are waiting to see what happens there.
We all know EE and like what EE has but EE was taking way too long to give the needed attention. My patience gave way and that is when we started talking to brand X. Brand X responded immediately and produced samples within two weeks and is even trying to manufacture a clip for us. As it stands for now...this next round of samples may be the last and deciding round. Just as a note, this time it took EE only two weeks to get something together.
7/7/15:
All samples that we will be receiving have been shipped and this should be the final round. For now we are at the mercy of shippers.
I think that the drivers are going to be where we need them and we are pretty much assured that we are getting a clip. It will also be packaged in a BLF box. In speaking with Banggood it looks like we may get this into production in the next couple of weeks, if not sooner. Many many thanks to ToyKeeper, Dale, Kronos, Wight, and Neal (Banggood) for all of their personal effort that has been put forth to make this a reality!
7/14/15:
Drivers from Brand X are here. Currently in the hands of TK and Dale for testing to ensure what is. So far they look good. Also waiting for samples to arrive from EE BUT no idea as to when they might arrive. Brand X is also the company has the deep carry clip, while EE does not.
I will see what tomorrow brings and reveal who Brand X is.
7/17/15:
Brand X is........
Manker
Way back when I started to get real frustrated with getting the original samples we went on hunt for a manufacturer that would be willing to listen to what we wanted AND provide the exact same. At that time EE caught wind and started to get on the ball but still difficult to communicate with.
Now.....
The biggest exterior difference is that Manker made a deep carry clip just for us and manufactured an A6 host to fit it because the standard A6 does not have a clip slot whatsoever. Manker will also allow us to order "naked" lights for those that want.
EE will substitute the A6 tube for an X6 tube...which is ok but "just ok" for and EDC in my opinion. I carry my F30 regularly and I do not like that it rides as high as it does with teh standard X6 clip....but that is me.
Inside....drivers are now manufactured the way we want. Manker's first sample had a two FET's....junk. EE sent samples with a single FET which was ok but not quite cigar ready in the efficiency department. EE also sent a 2 FET sample like Manker....junk too.
Manker samples we have and seem to be working although Dale's acted a bit wierd...TK's was perfect. It is enroute to TK now for neuro surgery Then EE samples as of now are MIA. For a fact they were sent but either customs is holding the container or the USPS has misplaced them - dunno.
Maker is anxious to get the ball rolling - hosts, clip, driver. Just waiting to see what happens with TK and Dale and hopefully the EE samples and we will be ......ready for it....sit down everybody >>>>>>>> DONE!!!
7/19/15:
See post 2465 for pics of Manker deep Carry clip and host
7/31/15:
I revisited the LED tints with Neal. We are being offered a 5A tint. We need to know how many are interested in that tint...especially in comparison to a 3C. Keep in mind that the light has AR glass and this tint may negate the unwelcome shift that occurs with 3C and AR glass.
I need immediate input from our member please so that we can get this out ASAP.
8/1/15:
Let me start out by saying that I had nothing to do with the availability of tint choices That credit goes TK, Dale, JohnnyMac, and of course Steve. My original request was 1A and 3C. Thanks to the people really doing the work the options are 1A, 5A, and 3D! I do not know what the bins are and I did request the V6 where possible but I will ask just so everyone knows but not that we can do anything to change anything
As of now..there are 1000 units slated for production. I do not know if more will be produced unless there is an immediate need or demand. In other words...after the buying slows down the production will stop and only what inventory is available will be available. It will not be re-introduced unless there is a super-serious demand. On the other hand Manker and Banggood may, and are free to do so, introduce a stock unit with these specs. Don't know so can't say.
Here's the status on production...
- The first 350 units are 1A. They should be ready sometime next week or the following Monday.
- The next 150 units are 5A. They should be ready about the same time with the 1A.
- After that there is another 500 3D. They are about 10 days behind due to the availability of copper.
It really has not been decided about the codes yet. I honestly do not know how to implement them other than just pm codes to the people that put their names on the list BUT that does not give any control over quantity ordered or sharing the code, etc. etc. To me it does not matter because even though they are staring with 1000 units they will produce 10,000 if the demand is there SO EVERYBODY WILL GET THEIR LIGHT(S). I will let the group decide how they would like that to be handled.
What I want to avoid is: "I ordered my light yesterday and it still hasn't shipped", "It has been 4 weeks and I still do not have it", etc. etc. If they run out of a certain tint they will make more, period. There will be a delay but that can be expected. PayPal gives us 6 months protection so I do not want to see people jumping the gun because they may be out of stock for a week.
My original intent was to get us a light mass produced with Wight's driver. Of course Dr. Frankendale showed us the possibilities. Then along comes this sorceress named ToyKeeper that showed Dr. Frankendale that she too can do cool things with lights. The rest is history. A truly custom light was born!
I am amazed by the amount interest in this GB as well as appreciative of everybody's patience.
I think I have everything
8/6/15:
Finally!! It has been a long road to get here. I never knew there was that much involved in putting together a custom light
This light is like no other budget light in existence and made specifically for us at BLF with components and firmware developed by BLF members. Throughout the process we listened and asked for improvements AND we got them. A couple examples are 1) The deep carry clip and 2) Instead of just DTP copper for the emitter this is genuine Noctigon. We even convinced the manufacturer to give us 3 tints. Of course 1A for the coolest max lumens possible, but also 3D instead of the usual green 3C and even 5A.
I thank everyone for their patience and support and a special thanks to our very own sorceress ToyKeeper (but in reality an angel in disguise!), Dr. FrankenDale aka Dale or DB Custom, Kronos aka Kronological, RemanG, JohnnyMac, and even Neal at Banggood (the list is too long to keep typing LOL)
Final Specs:
- XPL emitter in 1A, 3D, and 5A tints
- Up to 1600 lumens depending on battery used and spring bypass
- Noctigon Copper mcpcb
- A17DD-SO8 driver +1 7135 driver(FET for direct drive of upper upper and 7135 for regulation of lower modes)
- TK UI made by our own ToyKeeper (see some features) (Click HERE for more operation detail)
- User selectable 4 or 7 evenly modes (Moon to High)
- Reversing feature
- Moon capable
- Hidden blinking modes (inlcuding strobe and bike mode)
- Hidden battery check
- Low voltage protection
- User selectable mode memory (always starts on Moon without mode memory but easily reverses to Turbo with a click)
- Fast PWM for lower regulated modes
- AR Glass
- OP reflector
- Deep Carry pocket clip
- BLF-SE engraving
- HAIII Anodizing
- Packaged in a gift box
- Total Cost $25.00
A word of warning. This light is and only will be available at Banggood. No other reseller will have access to this light. Any claims or advertisements that another retailer has these can be assumed to false and the product to be counterfeit. This light will be available to those on the list and while there is demand. Once demand wanes this light will no longer be available except for Banggood's remaining inventory.
8/10/15:
Posted by Neal @ Banggood in post #3200:
Hello everyone,
The A6 are in engraving Logo,
1A 333 and 5A 167.
I test the lights, the drivers works perfect. and I think the drivers are the best I have seen.
Thanks Selene,Dale and Alex(wight) !!!
3D copper will be arrival this Wednesday and they should be finished this week.
I'm playing the light now and it makes me crazy!!!
Thanks for George,Steve,John,Selene,Dale and Alex(wight) and other members who join this project
8/12/15:
Links to pics
http://s25.postimg.org/bbt8evr27/50_A8_DBA2039_D72395_BC2111_A7_F3_FBA4_...
http://s25.postimg.org/km9xw5r5r/FFA900_B2_C717_BD4_F4_EFB376_F1242720_E...
http://s25.postimg.org/j5yfe0o8v/QQ_20150812091911.jpg
http://s25.postimg.org/3n0zgwfy7/QQ_20150812091859.jpg
http://s25.postimg.org/jg1cjmdhb/QQ_20150812091918.jpg
8/31/15:
For those that are having issues with their light, you can use this email address: heyanqing1@banggood.com
This and any problems need to be reported to Neal's assistant.
You can use this email address: heyanqing1@banggood.com
Interest List:
- Bugsy36
- Bugsy36
- Bugsy36
- Bugsy36
- Wedlpine CW
- Wedlpine NW
- Raccoon City
- Fireblade893
- Ricflair
- Beachlogger CW
- Beachlogger NW
- Dangerous NW
- Charga CW
- Calmaja NW
- Cliwilnew NW
- Werner
- Adoby NW
- Danielrhall NW
- DanielM NW
- Nguyen NW
- Nguyen NW
- TyBreaker
- TyBreaker
- Keengeorge CW
- Keengeorge CW
- Keengeorge NW
- Keengeorge NW
- Netprince NW
- Netprince NW
- The Burgh NW
- Patrickbateman NW
- Nisse NW
- Downlinx
- Adnj
- Adnj
- Steve-o NW
- Jmpaul320 NW
- Aslpg NW
- Aslpg NW
- Raven38571
- Sonofspectrum
- Martini
- Zelee NW
- Allthumbs NW
- DavidEF NW
- DavidEF CW
- Muto CW
- Muto NW
- Tryps NW
- Tristanxoxo NW
- D10ten NW
- M78 NW
- Kronological NW
- Kronological NW
- Kodachrome40 NW
- Viperbart NW
- Viperbart NW
- Absalom NW
- Dthoang NW
- Racer86 NW
- Kst NW
- Ncice5
- Syracuse NW
- Blueb8llz CW
- Blueb8llz CW
- Blueb8llz NW
- Blueb8llz NW
- B42 NW
- Southland NW
- Southland NW
- Ryansoh3 NW
- Prisma NW
- Gamezawy
- Stittville Ed NW
- Stittville Ed CW
- Bill 63 NW
- Xjsnake NW
- Xjsnake NW
- Clagged NW
- Billy X NW
- Kawiboy1428 CW
- Kawiboy1428 CW
- Kawiboy1428 CW
- Kawiboy1428 CW
- Nightspy CW
- Dodo NW
- MRsDNF NW
- Chazzy NW
- Otanacious NW
- Otanacious CW
- Freeme CW
- Freeme NW
- Qandeel NW
- Level NW
- Level NW
- James B NW
- Cajampa NW
- Gerrit CW
- Glowz NW
- Max CW
- Flomotion CW
- Flomotion NW
- BorisBar NW
- Hank NW
- ChibiM NW
- Minimoke NW
- Lite1000 NW
- Electricjelly NW
- Cone CW
- Cone CW
- Dondulah NW
- Dondulah NW
- Bigblockmopar CW
- Jim_r NW
- Ih8myx CW
- Ih8myx NW
- Krikstas NW
- 2 Dogs CW
- Dbss CW
- Dbss NW
- Jdunlap27284 CW
- Frankie Baby NW
- Boaz NW
- Boaz NW
- Boaz NW
- Boaz NW/(WW??)
- Cabfrank CW
- Alexey602 NW
- Meteorxs NW
- Scotlarock CW
- Scotlarock NW
- H-man NW
- Siata94 NW
- Embed NW
- Chicken Drumstick NW
- Randolph CW
- Newland CW
- Lawenforcementguy CW
- Joat NP
- Warhawk-AVG NW
- Warhawk-AVG NW
- Wdkingery NW
- Themaindude NW
- Themaindude NW
- Yourid NW
- Yourid NW
- Yourid CW
- Yourid CW
- Aardvark NW
- Sarge930 CW
- Sarge930 NW
- G60
- Chouster CW
- Albertopnp NW
- Will Manners NW
- Gj NW
- Gj NW
- Retiro675 NW
- Ryanferg NW
- Sandanbob NW
- Khas NW
- Khas NW
- Gleamer NW
- Trigger619 NW
- Trigger619 NW
- Trigger619 CW
- Trigger619 CW
- Nitro NW
- Msg1285 NW
- Rova2014 NW
- Saigon CW
- Sungsmith NW
- Spamman NW
- Xtrocity NW
- Zoom Zoom CW
- Bakalakos NW
- Wedlpine CW
- Wedlpine NW
- Djozz NW
- Moridin NW
- Bigblockmopar NW
- Calmaja NW
- Ilovejesuschrist NW
- Ilovejesuschrist CW
- SmokinH CW
- SmokinH NW
- Akoposilester NW
- Akoposilester CW
- Thebaum CW
- Jkbam NW
- Dbss NW
- Dbss CW
- Jensa41 CW
- Jensa41 CW
- Jensa41 NW
- Jensa41 NW
- Meyer NW
- Netjrb NW
- Netjrb NW
- Netjrb NW
- Netjrb NW
- Ger-slash CW
- Ger-slash NW
- Ray-o-light NW
- Can NW
- V.chiu NW
- Dthoang CW
- Tete NW
- Tete NW
- Fmc NW
- Megalodon NW
- Morris8809 NW
- Morris8809 NW
- Thebo NW
- Geo1952@gmail.com NW
- Gleamer NW
- Infinite NW
- Hannoveraner NW
- Koyotee NW
- Koyotee NW
- Sparkey762 CW
- Sparkey762 CW
- Sparkey762 NW
- Sparkey762 NW
- Hestbech NW
- Melven CW
- Johnnydoe NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Absalom NW
- Peetz NW
- Peetz NW
- Flashination NW
- Bdiddle CW
- Bdiddle CW
- Bdiddle NW
- Bdiddle NW
- Scuffy NW
- Mrsdnf NW
- Cabfrank NW
- Mfruit CW
- Lionheart_2281 CW
- Igor0203 NW
- Drjones NW
- Aardvark NW
- I.c.bacon NW
- Mg NW
- Plumrt CW
- Plumrt NW
- Plumrt NW
- C-channel NW
- C-channel NW
- Trigger619 CW
- Gunga NW
- Cellguy NW
- Cellguy CW
- Zipelgas NW
- Richnpc NW
- Trigger619 CW
- Trigger619 CW
- Docfar NW
- Docfar CW
- Urausb CW
- Sxv NW
- Sxv NW
- Sxv NW
- Lite1000 NW
- Ronmuller NW
- Luckyseven NP
- Eigenmeat NW
- Shuggarush NW
- Reavenger CW
- 1afc NW
- Eroheam NW
- Cbrake10 NW
- Cbrake10 NW
- Sigshooter NW
- Gunga NW
- Daylighter CW
- Daylighter NW
- Nbabu NW
- Mhanlen NW
- Seben CW
- Seben NW
- Scdaf NW
- DavidEF CW
- DavidEF NW
- Processengr CW
- Borisbar NW
- Billy x CW
- Tryps NW
- Tryps NW
- Mike72 NW
- Mike72 NW
- Mxdan NW
- Joat NP
- Joat NP
- Angel Martinez NW
- Saigon NW
- Halo NW
- WhitedragonBC NW
- Siata94 NW
- Hagg911 CW
- Hagg911 CW
- Fantomr NW
- Uqs1000 CW
- Uqs1000 NW
- Tapir CW
- Kodachrome40 CW
- Logindetails NW
- Logindetails CW
- Geo1952@gmail.com CW
- Plato NW
- Cliwilnew NW
- Cliwilnew CW
- Frankie Baby NW
- Frankie Baby CW
- Ray-o-light NW
- Kurt_norway CW
- Kurt_norway CW
- M4d m4x NW
- Presterjohn NW
- Seepeli NW
- Penumbra CW
- Hell2pay NW
- Hell2pay NW
- Hell2pay NW
- Hell2pay NW
- Rolz NW
- Zeremefico NW
- Prodal NW
- Cybertek NW
- Ronmuller NW
- Beam0 NW
- Will Manners NW
- Flomotion NW
- One41 CW
- One41 CW
- Richnpc CW
- Xp-r NW
- Xp-r NW
- Skippey NW
- Southcovekayak NW
- Southcovekayak CW
- M4d m4x CW
- Will Manners NW
- Will Manners NW
- Devman NW
- Devman CW
- Mfruit NW
- Caffeine_addict NW
- Ramblings CW
- Ramblings NW
- Streamer NW
- Pokemonrules NW
- G_sintornillos NW
- Cnrffl1 NW
- Seasam NW
- G0ose CW
- Xp-r NW
- Henk4u2 CW
- Hairy_Steve NW
- Bdivi NW
- Carmantl NW
- Carmantl CW
- Johnlate NW
- Vene67 NW
- Velectron NW
- Velectron NW
- Kickthecan NW
- Down_south NW
- Stefan NW
- Nclce5 NW
- Ackattacker NW
- Raygunz CW
- Modulor NW
- Rs4ever CW
- Rs4ever NW
- S1m888 CW
- Mizjif NW
- Shimey NW
- SciFiFreak NW
- Processengr NW
- Tommswpa CW
- Tommswpa NW
- Colliedoggy CW
- Xzel87 NW
- Alexey602 NW
- Alexey602 NW
- Colliedoggy NW
- Rs4ever CW
- Rs4ever NW
- Xzel87 NW
- Vladraq NW
- Gorky CW
- Gorky CW
- Lionheart_2281 NW
- Level CW
- Davx CW
- Gtsuperheroes CW
- Will34 CW
- P moore NW
- P moore CW
- Compression CW
- Compression NW
- Fragolino NW
- Ormbett NW
- Wobba NW
- Lab NW
- Manxbuggy1 NW
- Phatster NW
- Southland CW
- Southland CW
- Tristanxoxo CW
- Electroman187 NW
- Aznsw1mr NW
- Nitro NW
- Khas NW
- Khas NW
- Dmytro.shym NW
- A_idiot NW
- A_idiot CW
- Kiukas NW
- Kiukas CW
- Martini NW
- CircaM CW
- Jvarn81 NW
- Kbreeze NW
- Lux NW
- Scififreak NW
- Jamio NW
- Kensington CW
- Kensington NW
- Kensington NW
- Zipelgas NW
- JohnnyMac NW
- Antenne NW
- Johnnyc NW
- Zra NW
- Dsiddens NW
- Dsiddens NW
- J-dub74 NW
- Locusto03 NW
- Dantemens NW
- Chuckhov NW
- Chuckhov CW
- Brjones NW
- Kbro NW
- Nofear87 CW
- Xelario NW
- Thatdumbuser NW
- J-dub74 NW
- E10sno NW
- Mosesm NW
- Suncoaster NW
- Acmech CW
- Acmech NW
- Mauison NW
- Southland NW
- Southland NW
- Southland NW
- Southland NW
- Zra CW
- Wrathbringer27 NW
- Copperhead NW
- Urausb NW
- Corin NW
- Evilc NW
- Evilc CW
- Bwl123 CW
- Tigris99 NW
- Colliedoggie CW
- Colliedoggie NW
- Brno602 NW
- Bladesmith3 CW
- Bribo NW
- Cat eyes evil twin NW
- Bigrick CW
- Cul8r CW
- Cul8r CW
- Cul8r NW
- Cul8r NW
- Koaksijalac NW
- Eodoe NW
- Eodoe NW
- Zeng@LM
- P moore NW
- Toykeeper NW
- Toykeeper NW
- Toykeeper NW
- Toykeeper NW
- Jycheang NW
- Jubeldum NW
- Adoby NW
- Leelou NW
- Coolz NW
- Oscarm NW
- Smaller lights NW
- Smaller lights NW
- Smaller lights NW
- Smaller lights NW
- Jack-bkk NW
- Smaller lights NW
- Smaller lights NW
- Smaller lights NW
- Smaller lights NW
- Saypat NW
- Alphazeta NW
- Trume_3454 NW
- Melven NW
- Mwfire CW
- Dbsar NW
- Laythaws NW
- Argolite NW
- Mitko CW
- Mitko CW
- Mitko CW
- Mitko CW
- Mitko CW
- Processengr NW
- Mauison NW
- Dempsey
- Banker CW
- Fyesilova NW
- Abqjohnny NW
- Kronological NW
- Kronological NW
- One41 NW
- MG NW
- Fatsteve0 CW
- Fatsteve0 NW
- Spokeplanter NW
- Spokeplanter NW
- Incavin NW
- One41 NW
- Remang NW
- Remang NW
- Ih8myx NW
- Ih8myx CW
- Brno602 CW
- Trasnodel CW
- Angel Martinez CW
- Chuckhov NW
- Bribo NW
- Remang NW
- Tigris99 NW
- Hank NW
- Plumrt CW
- Plumrt NW
- Plumrt NW
- Djburkes CW
- Chenko NW
- Awoody001 CW
- Majster NW
- Darkerinsol CW
- Darkerinsol NW
- Trujunglst NW
- Lionheart_2281 NW
- Mikeyx NW
- Remang NW
- Chouster NW
- Gnr NW
- Mwfire NW
- Xed888 NW
- Paul321 NW
- Wieselflinkpro NW
- Stanley-beamish NW
- Tek NW
Pöbel
- Xsive CW
- Xsive NW
- Xsive NW
- Finges NW
- Patchman NW
- Natchteule323 NW
- Wapd2 CW
- Wapd2 NW
- Abang.tegak NW
- Abang.tegak CW
- Seenthelight CW
- Tarvos NP
- Tarvos NP
- Will manners NW
- Uiski NW
- Seasam CW
- Tank CW
- Raccoon city NW
- Raccoon city NW
- Mrcobra CW
- Mrcobra CW
- Ikaruz_500 NW
- Ikaruz_500 NW
- Ikaruz_500 NW
- Ikaruz_500 NW
- Gnr CW
- Kommessy NW
- Kodachrome40 NW
- Balinzwerg NW
- Chrigu CW
- Billy x NW
- Datsun NW
- Datsun NW
- Filedog NW
- Tissen NW
- Regaia NW
- Invisiblejules NW
- Invisiblejules CW
- Johnnydoe CW
- Uqs1000 CW
- Uqs1000 NW
- Box CW
- Box NW
- Chuckhov CW
- Tryps NW
- Tryps NW
- Plato CW
- Cobolt NW
- Cobolt NW
- Awoody001 CW
- Jack-bkk NW
- Corin CW
- Corin NW
- Wieselflinkpro NW
- Scooter000 NW
- Ahirshy NW
- Bastarrdo NW
- Seenthelight CW
- Weren NW
- Weren CW
- Grym NW
- Grym CW
- Jack-bkk CW
- Jack-bkk CW
- Gonein12 NW
- Sawmaster CW
- Bruno28 CW
- Unit311 CW
- Jamjar CW
- Jamjar CW
- Burnsd CW
- Burnsd NW
- Hellstone NW
- Mountainking NW
- Shanefletch CW
- Shanefletch NW
- Glas4d NW
- Mattlward NW
- Mattlward CW
- Zelee CW
- Cula NW
- Jtipp CW
- RockyMtnHigh CW
- Desidious NW
- Jtipp NW
- Dhsvcs CW
- Dhsvcs NW
- Sparkey762 CW
- Sparkey762 NW
- Sparkey762 NW
- Sparkey762 NW
- Guitar89 CW
- Guitar89 CW
- Nitro7 NW
- Kristoff CW
- Saypat NW
- Jeansy NW
- Le_zouave NW
- Sesgum NW
- Cavesprings CW
- Cavesprings NW
- Crashone NW
- Abril NW
- Clagged NW
- Clagged NW
- Clagged NW
- Blightsam NW
- Dogtown NW
- Del NW
- Level VW
- Crashone CW
- Hank NW
- Massimo.maronen NW
- Walty CW
- Walty NW
- Ledcoder CW
- Ledcoder CW
- Malenurse NW
- Down_south
- Remang NW
- Tom e NW
- Lopedevega NW
- Arekm NW
- Slow2go CW
- Slow2go CW
- Slow2go NW
- Zebroo NW
- Vuanhquoc CW
- Vuanhquoc CW
- Vuanhquoc CW
- Blinky1 CW
- Merikgver4 NW
- Malenurse NW
- Sigshooter NW
- Jealous57 CW
- Allthumbs NW
- Ronmuller NW
- Perttuj NW
- Theoldbill CW
- Lilien NW
- Vasa_visost NW
- Vasa_visost CW
- Down_south NW
- Gregor NW
- Bobofire NW
- Brightlights CW
- Woody NW
- Spokeplanter NW
- Spokeplanter NW
- Sandanbob NW
- Tas69 NW
- Drgadgetstein NW
- Drgadgetstein NW
- Roberrt777 NW
- Tedh35 CW
- Backpackerlight CW
- Backpackerlight NW
- Shadowfax NW
- Wrathbringer27 CW
- Teachtom NW
- Meti NW
- Guitar89 NW
- Itsonlyme NW
- Tryps NW
- Magnet CW
- Wobba NW
- Jref3 NW
- Gleamer CW
- Gleamer CW
- Tete CW
- B42 NW
- B42 NW
- B42 NW
- B42 NW
- B42 NW
- B42 NW
- Djozz NW
- Zebroo NW
- Gunga NW
- Lateotter NW
- Lateotter NW
- Burnsd NW
- Tommswpa NW
- Noki NW
- Hiker89 NW
- Hiker89 NW
- Compression NW
- Kafar CW
- Kafar NW
- Bill 63 NW
- Plumrt NW
- Plumrt NW
- Plumrt NW
- Merikgver CW
- Merikgver NW
- Xelario NW
- J-dub74 NW
- Cavesprings CW
- Cavesprings NW
- Abril CW
- Abril NW
- Keengeorge NW
- Keengeorge NW
- Docfar NW
- Richnpc NW
- Majszter NW
- Cabfrank NW
- Jaredm NW
- Ronmuller CW
- Twin towers NW
- Wrathbringer27 NW
- Wedlpine NW
- Wedlpine NW
- Jealous57 NW
- Chasealmighty NW
- Chasealmighty CW
- Chasealmighty NW
- Guitar89 NW
- Tjhabak NW
- Maxbeam NW
- Absalom NW
- Remang NW
- Remang NW
- Remang NW
- Remang NW
- Crowne NW
- Crowne NW
- Mike72 NW
- Lichan CW
- Eebowler NW
- Calmaja CW
- Remang NW
- Tkd15 NW
- Intracloud CW
- Intracloud NW
- Intracloud NW
- Thebo NW
- Ale9g NW
- Perttuj NW
- Gloomywarfreak NW
- Gj NW
- Gj NW
- Chibim NW
- Oscarm NW
- Oscarm NW
- Hein11ag NW
- Keepingitlight NW
- Keepingitlight NW
- Bikenber73 NW
- Bikenber73 NW
- Antilop65 NW
- Antilop65 NW
- Shanefletch NW
- Keithd CW
- Tas69 CW
- Minimoke NW
- Electricjelly NW
- Novice1 CW
- Myhken NW
- Myhken CW
- Lionheart_2281 NW
- Tristanxoxo NW
- Keithd NW
- J-dub74 CW
- Twin towers NW
- Maxbeam CW
- Maxbeam NW
- Vasa_visost CW
- Vasa_visost NW
- Glas4d NW
- Glas4d NW
- Thao916 CW
- Thao916 CW
- Thao916 NW
- Thao916 NW
- Dudunphy NW
- Le_zouave NW
- Jerrod NW
- Dudunphy NW
- Jack-bkk NW
- Ray-o-light NW
- Emerel NW
- Biolander NW
- Maiden666 NW
- Mike72 NW
- Dave101 NW
- Themaindude NW
- Sb56637 NW
- Archimedes NW
- Archimedes NW
- D10ten NW
- Jack-bkk CW
- Charga CW
- J-dub74 NW
- Tristanxoxo NW
- Tristanxoxo NW
- Netjrb NW
- Ahirshy NW
- Randolph NW
- Myhken NW
- Kriskras NW
- Bwl123 NW
- Syracuse NW
- Yoav.klein NW
- Yoav.klein NW
- Agiri CW
- Muto CW
- Muto NW
- Muto NW
- Bonner NW
- Gleamer NW
- Haro NW
- Qandeel NW
- Qandeel NW
- Gleamer NW
- Mrcobra NW
- Mrcobra NW
- Libretto17 NW
- Bobofire CW
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
subbed
Well the BLF X6 in the end had no moon nor the amps, so the whole debate was useless all in all.
How would the UI work with the A17DD-SO8 driver?
I would be interested in a couple.
If it will accept a protected 18650, I'm in for at least one.
31 knives for sale=USA only ☮♫☯
[WTS] Brand New Timex Expedition Vibe Shock Camo Watch [USA Only]
The atTiny is programmable. The way I understand is that the scale goes from 1-255. the max would be 255 (100%) and the lowest would be 1 (0.004%). I am not sure if a light can be run at "1" because I have yet to get into programming these things (and RMM has that moon special which unless single-sided is not a drop-in) but I do know that because we are speaking of an FET driver that the chosen battery gives a bit more control to the user.
Sounds good to me
Yup, I like the forum factor of this light. I am down.
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
I’m in for 1or 2
Will we get them in time for Christmas
depending on final details, I would probably be interested in 1
My Favorite Modded Lights: X6R, S8 , X2R , M6, SP03
Major Projects: Illuminated Tailcap, TripleDown/TripleStack Driver
Yes. How many would you like?
I’m interested.
BLF
Put me in the basket!
One in CW, please! Thanks!
' Lumen est omen '
Hope is no option!
Banggood has it now online:
http://www.banggood.com/Eagle-Eyes-A6-CREE-XP-L-800LM-4Modes-EDC-LED-Fla...
The normal version!
' Lumen est omen '
Hope is no option!
So will using A17DD-SO8? I’m in for 1 NW while waiting for further progress.
I would take one in NW
In
I'd like 1 x NW, please.
Interested in 1 NW, please.
1 NW pls
How would NW in this light compare to NW in the X6 BLF SE?
how does the A6 compare to the Convoy S2/3 ?
I would take one
Thanks
I’d be in for two.
Thanks!
Good Day Bugsy36,
As long as it takes Protected 18650 batteries, please put me down for 2 NW and 2 CW
Thank You Very Much,
George
Really can't say because I really do not know.
Are you referring to quality? I do not have one (A6) in my hand but both the Convoy and Eagle Eye are quality lights. I think that EE's anodizing is hard to beat (literally) when compared to any light.
Put me down for two – both neutral please! (sounds like a great GB)
Will this be equivalent to a convoy s2 stacked with 6 chips?
I need a couple tube lights that are bright.
Yes, quality but also design. Is there anything about one that is better than the other? Has anyone reviewed this light yet or are we going off of the qualtiy of other EE products?
It will be brighter depending on the battery used. The 7135's actually limit power were the FET does not.
