M4D M4X deals - if you want the BIGGEST discounts ;)
4898 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 11 hours 22 min ago
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
JasonWW
JasonWW's picture
Last seen: 2 hours 29 min ago
M4D M4X wrote:
Hello my dear friends!
today i received this deals:
Extension Tube for ASTROLUX MF01 MF02 MF02S MF04 MF04S
Spare Long Body Tube Set with Battery Holder & Plate
My Code: MMFET your price: US$20.99
I’m guessing it uses the stock carriers, but you have to use their special separator plate to maintain the stock 6 volts.
Click this to go to signature links.
lotrbfme
lotrbfme's picture
Last seen: 2 hours 31 min ago
M4D M4X wrote:
Turboglow Bead / FW3A Button and Gasket available!
Code : HTPGLOW
HTP WORKS TurboGlow Glow Gasket for FW3A & Carclo 105xx Optic
  • HTP WORKS TurboGlow Glow Gasket for FW3A & Carclo 105xx Optic
HTP WORKS TurboGlow Glow Gasket Button Cap for FW3A
also available: Carclo 10507 for FW3A
https://www.nealsgadgets.com/search?type=product&q=FW3A&aff=3
Martin, what difference can I expect when using the 10507 carclo instead of the stock optics? Thank you!
JasonWW
JasonWW's picture
Not much difference at all. The 10507 shows a bit more artifacts in the main beam. It might measure a bit more throw distance, but I can’t see any increase in throw.
lotrbfme
lotrbfme's picture
Thank you!
M4D M4X
M4D M4X's picture
Here is my next groupbuy for you:
LiitoKala lii-500S for US$ 21.90
LCD Screen Display Smartest Lithium And NiMH Battery Charger
Use my Code: MGL5S to get your price: US$ 21.90
please use my SHOPLINK
Features
  • 1. New touch control function;
  • 2. Four optional charging currents: 500mA*4/700mA*4/1000mA *4/2000mA*2;
  • 3. Two discharge currents: 250mA*4/500mA*4;
  • 4. It can charge different batteries of different specifications (18650/26650……/AA/AAA);
  • 5. This product uses a separate LCD display, charge and discharge mode (MODE). Voltage (V).    Current (mA). Time (h). Capacity (mAh) parameters, at a glance;
  • 6. CHARGE, DISCHARGE and TEST modes can work simultaneously; independently set charge/discharge capacity detection/normal capacity detection function;
  • 7. A variety of protection functions: overcharge and over discharge, short circuit, temperature,    0V voltage activation function, (-ΔV & 0ΔV), 1.65V-2.2V non-charging function, intelligent identification    of bad battery and reverse battery detection protection;
  • . With standard 5V/1000 mA USB output function (only valid when AC power is connected)
Package included:
1 x charger
1 x plug
slmjim
Last seen: 56 min 17 sec ago
Does this have a 3.7v~3.8v storage charge function?
slmjim
Great... Carnac the Magnificent tells me I just signed up for yet another expensive hobby.
Smile! It makes others wonder what you've been up to.
M4D M4X
M4D M4X's picture
I doubt that
which charger has that?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 days 11 hours ago
SkyRC MC3000 Smile
RapidLux
RapidLux's picture
Last seen: 8 hours 2 min ago
M4D M4X wrote:
I doubt that
I think one of Xtar’s new chargers has storage mode, was it VC4S?
JasonWW
JasonWW's picture
What the heck is Storage Charge function?
RapidLux
RapidLux's picture
JasonWW
JasonWW's picture
Why make a mode that stops at 3.7v when you can just take the battery out yourself at whatever voltage you want? I don’t get it. Is it just a made up new feature to make it sound better/cooler? That’s what it seems like.
tatasal
Last seen: 3 hours 32 min ago
My iCharger hobby charger has that very useful feature, especially for people who owns batteries that are ‘stored’ for years (like in my case).
Lilo cells are ideally stored at 3.7v for longest life expectancies.
Storage mode, when used, will bring up to 3.7v any cell below it and discharge any cell above 3.7v down to it, Automatically terminating at 3.7 while still completing the proper cc/cv protocol (this is different than just watching the display to 3.7v and taking out the cell).
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 24 min ago
It alams/stops when done or hits the target voltage if you will, so no spending time hawking the charger…..I have never used it…but if I did, I could appreciate this feature…
KB1428 “Live Life WOT
M4D M4X
M4D M4X's picture
all my cells are stored full - ready to use.
if I want to play with my lights I do not have be time for a charging session first Wink
texas shooter
Last seen: 6 days 4 hours ago
M4D M4X wrote:
all my cells are stored full – ready to use.
Can’t argue with that wisdom. I’ve yet to have used up a cells 500 lives yet, not even close.
RapidLux
RapidLux's picture
You can play a lot with your lights even at the voltage 3.7v-3.8v.
Keeping your cells at top voltage all the time, how many years does it take within you notice decrease in capacity etc. and it starts to be worn?
slmjim
M4D M4X wrote:
I doubt that
Opus 3100 has an internal switch that can be set to 3.7v, 4.2v or 4.35v. I've been using that.
slmjim
M4D M4X
M4D M4X's picture
slmjim wrote:
M4D M4X wrote:
I doubt that
slmjim
aaah - i remember!
thanks
leftdisconnected
Last seen: 12 min 56 sec ago
JasonWW wrote:
Why make a mode that stops at 3.7v when you can just take the battery out yourself at whatever voltage you want?…
To charge LiFePO4 cells. This charger does not support 3.7V or 4.35V chemistries, which most people will never need anyway. Multi-chemistry support is indeed mostly just for feature fluffing.
As others said, 3.7V limit is also useful for storing li-ion cells in their “relaxed” state. Even this is questionable, however, as they will still self-drain and require routine “halving off”. In actual “storage”, this maintenance seems unlikely to happen.
Adjustable voltage limits are useful, regardless. I’m pretty sure that TK charges her cells to 4.15V to avoid 100% top-off. I would do something similar if I could. Yes, this is unnecessary as our cells are quite durable even when kept at 100%, but some of us are geeks in different ways; I’m an optimizer by nature.
Imagine how annoyed I am that I cannot “fix” my smartphones to keep them from killing their own batteries Crazy . The desire for longer runtime right now means that they sacrifice long-term battery life. If there was just a setting to reduce the max charge to 96% or so like there is on my laptop…
RobAllen
M4D M4X
M4D M4X's picture
26 flashlights from 200 to 100000 Lumen
Quarry 2.0 - beamshot comparison
EcuBebge
Last seen: 9 hours 47 min ago
Any coupons for Convoy S2 Grey 7135*5 365nm UV Flashlight?
M4D M4X
M4D M4X's picture
my Link
Code: bgs2g
EcuBebge
Thanks!
amishbill
amishbill's picture
Last seen: 2 weeks 5 days ago
M4D M4X wrote:
my Link
Code: bgs2g
How did you know what I was looking for…
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
M4D M4X
M4D M4X's picture
LightObsession
Last seen: 1 week 1 day ago
Dang, it looks like I’ll be spending money on a Folomov Pen L1.
I like the C2 that I’ve had for a couple weeks.
LightObsession
Is $25 the discounted price for the Pen L1?
Thanks.
M4D M4X
M4D M4X's picture
LightObsession wrote:
Is $25 the discounted price for the Pen L1? Thanks.
no
