MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
hank
hank's picture
Last seen: 52 min 55 sec ago
Driver problem — I’ve just installed a 5×7135 driver (bought months ago) set up with Guppydrv
but it’s got next mode memory on all of its settings.
Any guess what I’ve done wrong here? Could I have grounded something with the retaining ring?
It’s running a PC amber emitter that also came from Mtn.
Oh, and the turbo timer drops down to moonlight, not to 50 percent.
Is there a way to cancel the turbo timer completely?
EDIT nevermind, found how to cancel turbo timer by setting to 4 seconds or less (info is on the page for the larger diameter driver)
And I found a thread about the next mode memory problem at: http://budgetlightforum.com/comment/1159984
John-Galt
Last seen: 1 week 3 days ago
Hi, RMM. Any idea when you might have Shockli 5500 mAh 26650’s back in stock? Thanks…
Firelight2
Firelight2's picture
Last seen: 24 min 23 sec ago
Richard is now selling e-switch drivers with the Emisar D4 UI v2.
It’s available now on his website in various sizes from 15mm on up.
This is great news for all modders who love the v2 firmware in the D4 and want to put it in their other e-switch lights.
RMM
RMM's picture
Last seen: 3 months 5 days ago
John-Galt wrote:
Hi, RMM. Any idea when you might have Shockli 5500 mAh 26650's back in stock? Thanks...
Hopefully soon.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
RMM
RMM's picture
hank wrote:
Driver problem -- I've just installed a 5x7135 driver (bought months ago) set up with Guppydrv but it's got next mode memory on all of its settings. Any guess what I've done wrong here? Could I have grounded something with the retaining ring? It's running a PC amber emitter that also came from Mtn. Oh, and the turbo timer drops down to moonlight, not to 50 percent. Is there a way to cancel the turbo timer completely? EDIT nevermind, found how to cancel turbo timer by setting to 4 seconds or less (info is on the page for the larger diameter driver) And I found a thread about the next mode memory problem at: http://budgetlightforum.com/comment/1159984[/quote]
If turbo timer is stepping down to anything less than 50% there is a problem.  To go any lower than 50% the driver thinks the input voltage is low.
Edness
Edness's picture
Last seen: 2 months 1 day ago
Richard, is this the same driver that came with the D4 v1? I have a v1 and I’d like to change to v2 if possible. I don’t mind getting the same driver with v2 firmware and replace it.
RMM
RMM's picture
Edness wrote:
Firelight2 wrote:
Richard is now selling e-switch drivers with the Emisar D4 UI v2. It's available now on his website in various sizes from 15mm on up. This is great news for all modders who love the v2 firmware in the D4 and want to put it in their other e-switch lights.
Richard, is this the same driver that came with the D4 v1? I have a v1 and I'd like to change to v2 if possible. I don't mind getting the same driver with v2 firmware and replace it.
No.  It is the MTN driver with the same firmware, not the D4 driver.  You'd be better off just reflashing the existing driver.
RMM
RMM's picture
Regarding the MTN Quad and Emisar D4 flashlight:
You can swap the MCPCBs directly, with NO SPACER required.  I had read some comments stating that a spacer is necessary, but doing the measurements and actually building some lights with the MTN Quad MCPCB it works fine without any extra spacer needed.
DB Custom
DB Custom's picture
Last seen: 5 days 2 hours ago
Could I put 4 XP-E2 Green emitters on your board and run em on the FET or would I have to reduce direct drive through PWM to keep from smoking the emitters like I did the Lee Filter I tried?
Maybe use the 18350 tube and a lesser cell to keep max current in check?
hank
hank's picture
The ‘next mode memory’ problem I have is probably a bad capacitor or two, as people described here:
http://budgetlightforum.com/comment/812126#comment-812126
and here:
http://budgetlightforum.com/comment/817220#comment-817220
Time for me to learn how to solder itty bitty things.
mattlward
mattlward's picture
Last seen: 14 hours 55 min ago
I must be blind, do not see them under FET or linear drivers…
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
RMM
RMM's picture
hank wrote:
The 'next mode memory' problem I have is probably a bad capacitor or two, as people described here: http://budgetlightforum.com/comment/812126#comment-812126 and here: http://budgetlightforum.com/comment/817220#comment-817220 Time for me to learn how to solder itty bitty things.
It can't be the capacitor.  Maybe we flashed it with the wrong firmware or something because there is not OTC on that 15mm 7135 board, so the capacitor will not affect the memory.
RMM
RMM's picture
mattlward wrote:
I must be blind, do not see them under FET or linear drivers...
It is a firmware option for the FET+7135 drivers---not a completely separate driver.
mattlward
mattlward's picture
RMM wrote:
It is a firmware option for the FET+7135 drivers—-not a completely separate driver.
Bummer, I need a couple of side e-switch drivers and had hope for a good driver with good firmware to replace a couple of factory drivers.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
hank
hank's picture
Did I say 15? It’s 17mm
Firelight2
And they are available. Just select the correct diameter of driver from the list of FET+7135 drivers, then use the dropdown menu to select D4 v2 UI.
Ford Prefect
Ford Prefect's picture
Hi Richard, what turbo timer option should I choose on the 17mm fet +1 driver with the D4 firmware? I wish to have the same configurable temperature step down as the D4.
Thanks
Ford Prefect
Firelight2
Thanks
Ford Prefect
I don’t think the D4 ui has a turbo stepdown, so you can just ignore that menu. At least that’s what I did with my order.
RMM
RMM's picture
Firelight2 wrote:
Ford Prefect wrote:
Hi Richard, what turbo timer option should I choose on the 17mm fet +1 driver with the D4 firmware? I wish to have the same configurable temperature step down as the D4. Thanks Ford Prefect
I don't think the D4 ui has a turbo stepdown, so you can just ignore that menu. At least that's what I did with my order.
Just ignore it.  It is going to be the same firmware regardless of what you select, like Bistro/guppydrv/moppydrv/Crescendo.
Ford Prefect
Perfect. Thanks
Sucker_Dad
Last seen: 2 years 9 months ago
I just received my first order from MTN and I am just really impressed with the quality of that L2 host. To be honest I bought the scratch and dent version and I don’t think anyone would know if I had said it was one of the first quality lights. I had to look at it for a bit and finally found 1 scratch on one of the fins on the head. The only thing I would suggest is throw in a couple screws to screw down the MCPCB with. But if that is all I have to worry about we are all good. Thanks a lot!
My apologies the screws had just really gotten hidden in the package. along with 2 centering rings and an extra spring. Thank you.
Ronin42
Ronin42's picture
Last seen: 7 months 2 days ago
Sorry of this has been asked (for the next D4 tranche)
ETA?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
T18
Last seen: 9 months 3 weeks ago
Has anyone offered to do any flashing of the first batch of D4’s..?
I bought 3 of the 1st batch and not quit up to flashing skill level so just wondering if there’s been any offers, can pay cash for flash or barter..?
RMM
RMM's picture
Ronin42 wrote:
Sorry of this has been asked (for the next D4 tranche) ETA?
Should be later this week.
RMM
RMM's picture
T18 wrote:
Has anyone offered to do any flashing of the first batch of D4's..? I bought 3 of the 1st batch and not quit up to flashing skill level so just wondering if there's been any offers, can pay cash for flash or barter..?
We will reflash them if you pay shipping.  Flashing is easy, getting the driver out without breaking anything can be difficult. Are you sure that you got the first firmware?  We only sent out a handful of lights with V1 firmware.  Quite a few with what I would consider to be V1.9 firmware (newer thermal throttling, but for more uses it is as good as V2.  If it blinks in the middle of the ramp then you do not have V1 firmware.
juaquin
Hey Richard – any chance of getting a S2+ host in Desert Tan? I know you haven’t even gotten the fully built tan ones in yet, but figured I’d ask if there was any plan for a host-only version too. I need a tan triple…
RMM
RMM's picture
juaquin wrote:
Hey Richard - any chance of getting a S2+ host in Desert Tan? I know you haven't even gotten the fully built tan ones in yet, but figured I'd ask if there was any plan for a host-only version too. I need a tan triple...
Yes.  We have both tan and clear S2+ hosts on order.
PBWilson
Last seen: 1 hour 16 min ago
Nice! I was thinking of ordering an 18350 tube in desert tan and grab some Aspire cells. I’ll be patient and get them from you when they arrive.
I may send my D4 to be re-flashed and then you can send them back all at once.
Now what else can I buy?
Firelight2
RMM wrote:
…Quite a few with what I would consider to be V1.9 firmware (newer thermal throttling, but for more uses it is as good as V2.  If it blinks in the middle of the ramp then you do not have V1 firmware.
Main difference I’ve noticed between V1.9 and V2.0 is that V1.9 has some bugs.
With my V1.9 light, I’ll start off in moonlight and after a second it will occasionally jump to max turbo…. not good if you happen to be staring into the emitters admiring the pretty tint. Don’t ask me how I know…. Evil
I’ve also noticed that sometimes my V1.9 light will start in moonlight and then step up to a low brightness on its own even when not being touched.
In all other respects it functions just like V2.0. However, V2.0 is better because it has no bugs.
Newlumen
Newlumen's picture
Last seen: 2 months 4 days ago
Hi mtnelectronics, i was told shockli 26650 5500 mAh in button top are available. When will you stock them? Thanks.
