FWIW is it realistic to state that an XP-L version will ‘only’ incur a $6 premium?
A Noctigon M43 Meteor with XP-L HI emitters is only $30 more than one with XP-G2 or Nichia 219c. That’s a delta of $2.5/LED, retail.
That’s a beautiful boutique torch, pretty much built to order, where choices of LED, external finish etc. can be selected, then waited for.
Like a posh handbag.
At a premium price.
Still, we are talking about $7.5 extra by your numbers for three emitters. That’s not going to work for a $30 torch.
As for “only $30 extra”, well, that’s a first-world problem.
Much as I like the idea of the Meteor, I find my Astrolux MF-01 (second edition) with x18 emitters behind an excellent TIR array more to my liking. It is clumsy crude and heavy by comparison but it works superbly, at a fraction of the price.
Edit: Seriously, no need for voters to see the result emerging AKA exit polls, and be aware that if you put you’re email address into the box instead of a pseudonym then it will be available for all to see.
Edit: It should be blind. Too easily gamed (I’ve decided to not participate except for one vote, because I have some scruples left).
After these supposedly (I guess???) ‘tongue in cheek’ remarks & suggestions…… maybe it would be a great idea to not count anonymous votes at all.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Invalid vote
Confusion
To vote 1 is to put it in first place?
or do I prefer to vote 5 and give 5 votes?
My favorite is XP-L
I gave him one vote. Was I wrong?
You are right. I think XP-L should not be favorite but your favorite is 1.
1 = first place = favorite
2 = second place = next favorite
5 = last place = worst
If you do not want to choose between one thing and another thing, you can give them the same number (a “tie”) for whichever number they are. So you could pick 5, 2, 3, 3, 1 if you want.
Some combinations of emitter and cct do not exist, so if for instance 4250k wins and we cannot buy an emitter in 4250k so we have to see what else to pick. Or maybe we tested one cct of an emitter but 6500k wins somehow and that emitter is very bad in 6500k; we should not use 6500k in that case.
Fortunately, these ranked results work such that it’s very easy to pick the highest-ranked CCT that exists for a given emitter and still know that the majority prefers it to every other option that exists.
It’s a bit harder to know that everyone would prefer say… a 4000K LH351D (which exists) to a 4500K 219C (which doesn’t exist), but where people haven’t voted anonymously, it’s possible to correlate preferences to a degree.
Ceilingbounce – flashlight testing and runtime graphs for Android
If I get time I may do some beamshots with all 10507 optics. I do have a single 10508 and 10511 but i’m not sure I want to go swapping all the optics. I just so happen to have these in triples:
Jaxman E2L:
Nichia 219C D240 4000K 90CRI
LH351D 4000K 90CRI
Convoy S2+:
XP-L HI V2 5D 4000K 70CRI
Just from my own description though I feel like it needs to be emphasized that the LH351D has NO hotspot AT ALL. It could pass for a mule. I have reflector based lights with this LED in them that do show a hotspot but all of these TIRs totally smooth it out across the entire beam.
From the stuff I’ve seen about it, while it’s not got a defined spot, it’s also nowhere near the almost 180deg of a mule; it’s just got the even circle aspect. Would be neat to see, even if the drive current’s not the same.
You are right, the beam width is not the same but I more so meant the fact that it looks like a very “even” circle all the way to the edge. If it’s more intense in the middle you will not be able to notice.
It’s worth repeating that the poll is what we ask for, not necessarily what we’ll actually get.
For example, the current results show LH351D and 4500K in the lead, but the LH351D does not exist in 4500K. Neither does the 219c. Cree has a wide range of tint bins from 4000K to 5000K, but the Samsung and Nichia options are only 4000K or 5000K with nothing between.
So, to get 4500K, only Cree emitters work. Or to get LH351D, only 4000K or 5000K works (and it doesn’t appear that BLF has tested the 5000K 90CRI version yet).
In a few days I’ll probably make something to scatter-plot the data to check for emitter+tint correlations in case there are any useful patterns.
Hmm. I had forgotten about the limited tints available in the 219C (and I had no idea what tints are available for the LH351D). So I just answered them independently. Maybe there should only be one poll with the actual available options, because I care a bout getting a Nichia or a Samsung much more than I care about the difference between 4000K and 4500K (and I don’t really want any of the Crees).
Neither the 219C nor the LH351D come in 4500K. Both come in 4000K and 5000K.
I’d be pretty happy with 4000K, 5000K, Samsung or Nichia as long as it’s 90 CRI. If Cree made a 90 CRI, neutral white XP-L HI, I’d be happy with that too (I have a shaved 4500K 90 CRI XHP70 and it’s pretty nice).
What he said…
Indeed, it is bizarre to have two polls simultaneously, one for CCT, the other for emitter choice/CRI.
Unless it is a student project to garner some theoretical data to be written up for finals.
Make it real, i.e. the actual possible choices. One poll.
Otherwise I will have to get my head around how to vote tactically for what I want (4000K Samsung, or Nichia, though I don’t really want a Nichia but it seems to have a cult following based on past history when that’s all that there was)
I think it’s more a known quantity thing. I can buy a Jaxman or Emisar with a 219C (and I have), so I know I like those. I’ve read reviews of the Samsung, and I would like to try one, but until and if the FW3A is available with a Samsung, I have to learn how and get the equipment to reflow emitters just to try one. That’s a big commitment for some of us. Well, I couldn’t find any MCPCBs with Samsungs already soldered last time I looked. That could have changed.
the beam comparison photo went a Loooong way to allay fears that the floodier beam would not have enough throw.
To be fair, that tree is only like 10 meters away. I find the floodier option not to be very useful outdoors, because the foreground is always so much brighter than the target. So I plan on having XP-L HI in mine, even if I have to swap the emitters. Maybe I’ll pay an extra $20 to get a MCPCB pre-made from Mtn, but I’d rather just pay an extra $6 and not have to solder anything.
Unfortunately, there aren’t many Condorcet voting services which can do more than one question in the same poll, and I haven’t found a survey site which has good voting systems. So it’s really awkward to gather two preferences at once.
It could be done by multiplying the options, but that would make an awfully long ballot with 30+ candidates for each person to rank.
At a premium price.
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
4500K Samsung LH351D and I am sold
sst-20-w
Please add me to the interest list for one.
Absolutly the same, please
Ok, I’m in for one.
Refugee from CPF and long time lurker on BLF.
Ratus_ on r/flashlight.
1536 on the GT List, Arrived 05-23-18
1271 on the FW3A List
Card Carrying CRI baby
Can I be put down for one please.
Yeah, but if a 4500k 219c was available but wasn’t very good, we’d have to reconsider, right?
Interested in one, possibly 2.
Jaxman E2L:
Convoy S2+:
Interested!!!
Ah. Well that’s fine with me then.
What he said…
I’m interested in one, thanks.
Will it accept a protected cell? I mean one with built in charger.
Interested in 2, thanks!
Wow
that is an outstanding poll, and the beam comparison photo went a Loooong way to allay fears that the floodier beam would not have enough throw.
the detailed voting tally is an extremely useful way to visualize different members preferences and priorities
so far the majority, 58%, prefer the High CRI LH351D over the Low CRI XP-L Hi
I must admit I am suprised, as I though based on the Vocal Minority comments that the XP-L would be the favorite
It renews my faith in the possibility that the FW3A project will produce a High CRI light option.
How to hide signatures, and ignore someone, http://budgetlightforum.com/node/44835?page=3#comment-1438048
I would like 2 please.
