13637 posts / 0 new
hyperduc
Last seen: 1 year 3 months ago
JasonWW wrote:
hyperduc wrote:
I saw maukka’s updates on page 220. The light looks really sharp. Were there beamshot photos of the recent sample posted?
Waiting to hear about how the orders will work because I will likely order more than one. All LH351D 90+ CRI.
I see it has been confirmed it only works with unprotected cells due to length. I only have MTN protected NCR18650GA cells now but I suppose I can buy a few unprotected for this light. Would be convenient if it were compatible with both but it’s ok.
Interesting, I see the 30Q has much less sag at 7A, but has less capacity overall and is equivalent at lower currents.
What is the DD current expected to be for this light?
So, button or flat top?
From MTN:
30Q Unprotected button top = 66.6mm
30Q Unprotected flat top = 64.9mm
NCR18650GA Protected = 69.0mm
NCR18650GA Button Top Unprotected = 67mm
NCR18650GA Flat top Unprotected = 65.5mm
Maukka has not posted beamshots yet.
Ordering details have not been announced, yet.
Amperage should be under 15A, but I’m not sure how much under. It will vary based on battery and led. We should get some exact numbers once the prototypes get delivered and measured.
You want to use unprotected flat top batteries.
Unprotected button top may or may not fit as they vary in length.
Thanks Jason.
I will likely choose the VTC6 flat top, with 30Q flat top being the second choice. I don’t know how the internal resistance of the two compare but I suspect it is slightly higher on the VTC6 which would be OK if a 30Q works.
cabfrank
Last seen: 2 hours 3 min ago
As TK said above, the 35E will work really well for run time. The LG MJ1 would be great too. They have more capacity, and are not quite as high drain, which would be ideal for this light, since maximum brightness is not the goal. I will just be using the unprotected flat tops that I already have.
teacher
teacher's picture
CRX wrote:
Yeah, glass is a window unless it’s got curves.
Thumbs Up ….. So do we need to inform the guy, in the quoted post below; that broke the glass on his Sofirn SP33 that he is actually seeking a replacement window…. not a replacement lens??
Sorry... I just couldn't resist. . Big Smile . Wink
http://budgetlightforum.com/comment/1452496#comment-1452496
Hawaiian Eyez wrote:
I have a stock SP33 that I accidentally dropped and the glass cracked… anyone know where I can get a good, inexpensive replacement lens?
maukka
maukka's picture
Last seen: 18 hours 17 min ago
BlueSwordM wrote:
Also, could you check with a magnet if they are steel springs or not?
Neither of the springs is attracted to a magnet.
CRX
CRX's picture
Last seen: 1 day 22 hours ago
Yep, we try to help.
This guy will have problems buying replacement lens for the house too.. Big Smile
finges
Last seen: 1 day 15 hours ago
Interested in one with LH351D !
joechina
Last seen: 1 week 4 days ago
I think it will be difficult to measure current. You can’t take an easy tailcap reading.
One possiblity is with no optics you can extend one lead for the LED and feed that through your clamp meter.
But it seems the optic clamps the LED-BOARD on the shelf?
You need an assistant who press with tweezers the board manually down?
teacher
teacher's picture
Thumbs Up … He certainly will. Shocked .. Big Smile
JasonWW
JasonWW's picture
Last seen: 2 hours 10 min ago
I don’t think it will be too hard. Use one hand to hold your main jumper wire to the threads and the other end to the battery.
Then use your other hand and a wire or piece of metal to jumper power to the inner tube. It might be tricky to get two fast touches so as to activate Turbo, but it looks doable.
maukka wrote:
Nev
maukka wrote:
I also think it’s strange that my “production” sample has a cool white (>5700K) emitter.
You lucky thing ,that’s my favourite tint Love
WolfA
WolfA's picture
Last seen: 1 year 6 months ago
I’m in for one please!
"A black bulb which, when switched on, turns the room dark"
(Gyro Gearloose)
kanton
Last seen: 3 weeks 6 days ago
maukka wrote:
I am confused – is the inner tube fully anodizer even on its ends? How does it make contact?
kent21972
Put me down for one, please.
mortuus
mortuus's picture
Last seen: 2 hours 7 min ago
what is the inner tube needed for? im confused.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
maukka
maukka's picture
Muggle mode has an output range of 5-240 lumens.
maukka
maukka's picture
It’s the conductor for the tailcap e-switch.
It’s not anodized, just looks black in the photo.
MascaratumB
MascaratumB's picture
Last seen: 8 hours 42 min ago
It’s so good to see this alive Love
It is looking fabulous Hat
For those who may be interested in a GAW of this light, check my signature and, if it is the case (see rules in post#1), get IN for the GAW Beer
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
mlodyulek
Last seen: 1 month 6 days ago
I’m already in for one but count me in for one more.
Zulumoose
Zulumoose's picture
I don’t suppose this is possible, but since the FW3A is being shipped with a frosted lens leaning towards flood, and it is meant as an EDC light, for which a mixed beam would arguably be more suitable, what are the chances of having an extra lens type or two for variety as an optional extra to be selected when ordering if so inclined?
I certainly wouldn’t want to start sanding my ONLY lens, I would rather swop and experiment with spares, but separate orders mean more shipping and receiving fees, not cost effective on such small purchases.
Beam me up!
JasonWW
JasonWW's picture
It’s a narrow beam, lightly frosted lens which makes the beam look much nicer plus gives a little extra spill light. It should not lean towards being floody. Here is the 10511.
I doubt Lumintop would offer extra lenses, but maybe Neal would.
The problem is what other lens would they carry? MTN E carries 5 different ones and there’s probably more than that.
Maybe a clear version of the narrow beam, the 10507? I guess it would be the next most likely one people would want. Just keep in mind that it can produce some ugly artifacts which is why it’s not used in the first place.
ToyKeeper wrote:
With a 10507 optic the beam is basically just a circle, almost like a narrower version of how a zoomie looks in wide mode. At the edge of the circle it has an off-colored corona, and then outside of that is a barely perceptible spill area in the shape of a triangle. So for practical purposes it’s a hotspot-only beam with no significant spill, and the hotspot has a thin warm corona around the edge. It looks a lot like a blurry projection of the sun.
With a 10511 optic the beam is totally smooth and has no sudden changes in tint, temperature, or brightness. So I’m keeping the 10511 in mine.
ToyKeeper wrote:
I still think 10511 is Where It’s At. Big Smile
For XP-G2, the official specs are:
  • 10507: 4.8 cd/lm
  • 10511: 5.5 cd/lm
For XP-G3, the ratings are lower:
  • 10507: 3.1 cd/lm
  • 10511: 2.7 cd/lm
Nichia 219c has similar ratings:
  • 10507: 3.3 cd/lm
  • 10511: 2.9 cd/lm
Not sure why the relative throwiness reverses sometimes, but the 10511’s throw increases if you polish the frosted part by rubbing it on fabric or something… and afterward it still has less corona artifacts than the 10507. It’s too bad they don’t seem to come in a non-frosted 10511 variety.
Here are a few configuration estimates, taking into account the optic specs and an estimated lumen count:
  • 219c w/ 10507: ~3000 lm, ~9.9 kcd lux
  • 219c w/ 10511: ~2950 lm, ~8.5 kcd lux
  • XP-G2 w/ 10507: ~2500 lm, ~11.9 kcd lux
  • XP-G2 w/ 10511: ~2400 lm, ~13.2 kcd lux
  • XP-G3 w/ 10507: ~3600 lm, ~11.1 kcd lux
  • XP-G3 w/ 10511: ~3500 lm, ~9.5 kcd lux
  • XP-L HI w/ 10507: ~3350 lm, (no cd/lm data available, guessing ~18.7 kcd lux)
  • XP-L HI w/ 10511: ~3300 lm, (no cd/lm data available, guessing ~20.8 kcd lux)
These are all totally theoretical though, using numbers from Carclo’s specs and measurements of similar lights. They’re probably pretty far off from reality. Mostly I just wanted to show that there are a variety of sweet spots for different use cases. The FW3A’s specified config is one of those sweet spots, but other options might be interesting later too.
Mostly, I just think the 10511’s beam looks a lot smoother, and the difference in throw is usually small. Here’s how they compare in two of my lights… 10507 on the left, 10511 on the right:
(in case the quality of the embed is low, here’s the direct link: https://www.youtube.com/watch?v=UnWO8iN4Fzg )
JasonWW
JasonWW's picture
Toykeeper, could you maybe put your beam shot comparisons of the different lenses, or a link to them, somewhere in the beginning of the thread? That way people can find them easily.
Sorry, I can’t find the post. I’m pretty sure it was you. Maybe it was someone else. I remember they were like backyard night shots showing the hotspot size and amount of spill light.
iamlucky13
Last seen: 7 hours 7 min ago
hyperduc wrote:
What is the DD FET current expected to be for this light?
I’d guess 10-15A.
Although the 35E and 18650GA are rated for 8A and 10A respectively for continuous drain, they seem to handle 15A reasonably well for short periods of time.
The 30Q and VTC6 might be better choices if you plan to run on turbo a lot, but the heat generated by the FW3A in turbo will be more of a limit than the battery.
Megapanda66
Please put me down for 4 more (total of 6)
contactcr
Last seen: 7 hours 29 min ago
I think that was different emitters, not lenses.
The video you quoted is fine for showing the smoothness and edges of the beam but it doesn’t portray what happens at several meters. The 10511 gets pretty wide and doesn’t show a strong hot spot like it does in this short distance.
DB Custom
DB Custom's picture
Last seen: 1 month 1 day ago
The glass covering in a flashlight that protects scratching of the optic or reflector and allows for protection from water and dust ingress is a lens, simple as that. Anyone arguing this is a troll. Silly
Edit: Of course nothing is simple and depending on how technical one wishes to go there are variables, but in ordering a replacement for your flashlight it will be called a lens. Wink
JasonWW
JasonWW's picture
It was a while back, so I can’t be sure. I seem to recall the different amounts of spill light, though.
Maybe someone has some beam shots of just the different lenses to give us an idea of the differences.
I’ll probably keep the frosted lens. My previous lights had clear optics and I never liked the lack of spill light from them. I prefer a reflector type beam pattern and the frosted 10511 seems very similar to that.
cdjaney
cdjaney's picture
Last seen: 1 year 18 hours ago
He said “ingress”. No correcting that! Well played DB…well played. Big Smile
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
JasonWW
JasonWW's picture
I don’t think anyone was calling the glass part an optic.
We are just saying there are two lenses. Both the glass part and the molded plastic part can be called a lens.
DB Custom
DB Custom's picture
Well, they can be called toast if things go awry, but the people that make them call them optics… this is because they are computer designed to align the transmittance of the lights rays, guiding the egress of photons to a predetermined focus… hence, optics through reflective manipulation.
Streamtronics
Streamtronics's picture
Last seen: 1 min 55 sec ago
g_damian wrote:
Why 7135s on the driver in maukka’s picture are in such unusual position? AFAIK it’s not good for heat dissipation.
What do you mean? The way I understood it, the driver has eight 7135 regulators in total – there is only limited space available on the PCB so six of those are located at the bottom (spring side) of the double-sided PCB. Where else would you put them?
They don’t actually dissipate all that much power – when all eight are 100% on, I’d assume the driver dissipating around 2.5 W total (worst case) when the battery is at 4.2 V.
