13582 posts / 0 new
Mr.Scott
Last seen: 5 days 4 hours ago
The Miller wrote:
Since Mr.Scott showed how cool and good his program works I have not added anybody to the pm list so that will be done at some point, don’t worry if needed I’ll add all manual again and if Mr.Scott does it there is no rush either Wink
And list updated, pm list removed for now Smile
I’m happy to generate the PM list.
The Miller- let me know when you want it.
The Miller
The Miller's picture
Last seen: 7 months 1 week ago
Thanks Mr.Scott!
Awesome.
Not now, when we get closer to finalisation is perfect!
Mr.Scott
By then I may have finished the automated sending of PMs, not just generating the PM lists. I’m working with SB now on testing.
Twistedvizionz
Is it to late to get on the list for 1.If not out me down for 1 please
DavidEF
DavidEF's picture
Last seen: 1 day 7 hours ago
Wow! This forum is getting better all the time! And it’s all because of members taking up the mantle and making things happen! Thumbs Up
- The YKK Philosophy
ifratos
ifratos's picture
Last seen: 1 month 4 days ago
I’m in for 1 ,please.
And God said, Let there be light: and there was light.( Gen.1:3)
The Miller
Welcome to BLF!
Will update list later!
Yeah awesome!
Gladimir_Gluten
Gladimir_Gluten's picture
Last seen: 1 year 1 month ago
I am interested, thanks!
DrHook59
Last seen: 6 months 4 weeks ago
I’d be keen for one of these too, please Smile
Marothar
Last seen: 7 months 4 weeks ago
Hello!
I would also like to be added to the list please!
The light looks very good!
Thank you very much!
The Miller
Yes will update list soon
And Fritz is finalizing the driver, hope it can be presented soon for it is a thing of beauty!
DavidEF
DavidEF's picture
hanoilighting208 wrote:
Its structure is nothing special
That may be true. But, why did you feel the need to make that comment here? Do you wish to elaborate on your statement?
Bạn có thích đèn pin không? Bạn sở hữu bao nhiêu? Innocent
rizky_p
rizky_p's picture
Last seen: 1 week 2 days ago
anyone know how many lumens this flashlight will pump out, or how hard it is going to be driven?
The Miller
Wrong topic?
Or what do you mean?
The driver structure is special, The double tube structure is special.
The tail switch construction is special
Yeah the optics are if the shelf, you mean that?
We have to test actual lumens, let’s keep it at 2000-2500 Smile
DavidEF
DavidEF's picture
http://budgetlightforum.com/comment/1156936#comment-1156936
fritz15
fritz15's picture
Another small update, the driver is basically done Smile Here are the pictures from oshpark.
Board Top
Board Bottom
Top Layer
Bottom Layer
At this point I’d like to thank DEL who patiently answered all my stupid questions and consistently gave advice on the schematic as well as the layout of the board Smile
Tjohn
Tjohn's picture
Wrong topic?
Nothing Special?
What Polka dot colors does Fritz need to add to the PVD formula?
That was all I needed to read.
OK ……. The Miller please slip me into the waiting line for 3 of these.
AEDe
AEDe's picture
Last seen: 2 hours 16 min ago
fritz15, could you tell dimension of driver d and h ?
DavidEF
DavidEF's picture
Board Top
Board Bottom
Top Layer
Bottom Layer
Nice! Thanks for showing this! Are these boards shared on OSH Park, or you keeping them private?
leroycp
Great job and thanks for sharing!
fritz15
fritz15's picture
I don’t see why not. But unfortunately, the driver is made specifically for the FW3A and won’t fit for other lights due to the second tube. I can add the link to oshpark when the driver version is final Smile
The Miller
Thanks for sharing Fritz!
I so DIG this pic:
Just dang beautiful!
Sweet
Gonna edit the title and OP later for the unveiling of a new BLF special driver PCB certainly deserves that!
DavidEF
DavidEF's picture
Yeah, it won’t fit any lights that aren’t made for it. But, if it’s available, somebody can make another light to fit it if they want to later. Also, if somebody had a driver fail for any reason (not covered under warranty Evil ) they could build a new driver themselves.
Hairy_Steve
Last seen: 5 months 5 days ago
Looks nice.
Add me to the list for 1 please
joechina
ToyKeeper wrote:
This should be fairly similar to the D4, except:
  • Tail switch instead of side switch. (both momentary electronic switches)
  • 3 emitters instead of 4.
  • FET+7+1 driver instead of FET+1 (so, more efficient and higher regulated modes).
  • Narsil UI instead of Ramping IOS UI.
  • Different body style.
  • Extra pin wired up for aftermarket light-sense hacks.
At a guess, probably ~140 lm on the “1” channel, ~1000 lm on the “7+1” channels, and ~3000 lm on the FET channel. With smooth ramping from moon all the way to maximum. Or discrete levels if you prefer.
Anything up to 1000 lumens should be reasonably well-regulated.
I’m assuming I should (or someone should) probably put in some proper thermal regulation before the FW3A is released, but that probably won’t be too hard.
Putting in a blink at channel boundaries shouldn’t be hard either, but it depends on if that feature is desired.
I would also love the default memory value for one channel. I don’t know if this works with the double tube.
The Miller
The double tube is to make the switch work, does not affect the UI in any other way then making sure it can work Wink
ifratos
ifratos's picture
The Miller wrote:
Welcome to BLF! Will update list later!
Thanks! I forgot to tell but I assume that you know :
I am John(Ion in native) and I am flashoholic.
joechina
Damn, I checked the size of my SK68.
FW3A and SK68 have the same size!
Max. outer diameter and length
That’s compact for a 18650
akoposilester
akoposilester's picture
In for two pcs. Thank you
FL Newbie
joechina
Thanks The Miller!
Could you add in the OP where the size is mentioned: “This is as small as a SK68” ?
Many know how pocketable a SK68 is and an now the FW3A with the power of a 18650 Smile
