13583 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 11 hours 31 min ago
mbp wrote:
I just received a new bare aluminum FW3A from Illumn, it has the tail retaining ring so I know it’s a newer run. I have noticed that this model has a gap in the clip ring area and the clip can spin freely, it has already scratched up the body quite a bit. My other FW3A is from the first SST-20 run and it has no gap and the clip cannot move. Has anyone else observed this behavior? A little disappointing.
Where is the rubber ring? If it’s not there or it’s too small, you can add one so it won’t spin.
contactcr
Last seen: 2 hours 35 min ago
The new models do not include any rubber ring for the clip and on top of that they now put solder blobs on the back of the switch PCB so the tail wont even crank down as much. I think both of those issues lead to this.
ToyKeeper
ToyKeeper's picture
Last seen: 19 min 23 sec ago
staticx57 wrote:
ToyKeeper wrote:
goshdogit wrote:
DarkHorse UI on the FW3A
I don’t have that one updated to work with three channels…
Out of curiosity, what is needed? How doable?
Not sure, but it would probably at least need to be updated to support Anduril config files.
It really hasn’t had any meaningful updates since it was first written. Just barely enough to allow it to compile after changes in FSM.
Chatika vas Paus
Last seen: 32 min 29 sec ago
Is anything known about the other colors of the 18350 tube?
I would like to have purple and copper.
tatasal
Last seen: 2 hours 29 min ago
The FW3A family has the upcoming addition: Stainless Steel !! ..it will be called FW3S
raccoon city
raccoon city's picture
Last seen: 21 min 40 sec ago
Very good looking.
Of course it'll heat up quickly, but it's still tempting.
mortuus
mortuus's picture
Last seen: 10 hours 11 min ago
copper version the polished is sold out now according to lumintop on facebook.
...where Frugal meets with Flashlight!
Mr.Beam
Mr.Beam's picture
Last seen: 3 weeks 19 hours ago
according to statement by lumintop the short tubes won’t be available until further notice with other colors or materials than the standard gray fw3a unfortunately:
“We regret to tell at present, we have no plan for the blue/sand/raw/green/purple and titanium/copper short tubes yet. Because the total volum is not as much as the color grey version, so if we made the colors short tubes, the quantity will be less, thus the cost will be high.”
too bad Sad
fw3a and fw3t on holiday at the beach
atobe
Last seen: 1 hour 15 min ago
Are they just willing to sell the bezels for tail-cap and head?
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
P33
Last seen: 2 days 19 hours ago
Gunga wrote:
I wonder if anyone can confirm that the 18350 tube works with the first gen body.
18350 tube does work with the first batch FW3A without any issues.
MascaratumB
MascaratumB's picture
Last seen: 4 hours 6 min ago
And the 18500 tube, and the SS bezel and the deep carry clip also work perfectly with the 1st batch of this light!!! Love
(P.S. nevermind the light temperature of the photo, it is not balanced and is under a lower than 4000K ceiling lights)
BTW:
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
icpart
Last seen: 11 hours 2 min ago
Hi. Today I received my FW3A SST20. In the package there is warning to not dissamble the tailcap, but when I tried to unscrew it, it was very tight and I could not to remove it. Do you have idea if in the last batches of FW3A the tailcap is maybe glued?
atobe
It should have a retaining clip that holds down the tailcap parts. Look for a black ring.
icpart
I can’t just unscrew at all the taicap. Any suggestions? OOps Blushing it was just very tighten.
Finaly managed to unscew it.
M4D M4X
M4D M4X's picture
Last seen: 4 min 20 sec ago
you did read the notice to open the head to insert the cell and NOT the tailcap?
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
trakcon
trakcon's picture
Last seen: 1 hour 3 min ago
Mine was tight, but no glue.
icpart
Yes I know that. I wanted to just measure standby current and maximum power consumption with my battery so I needed to uncrew the tailcap. It was just very tight.
atobe
Oh I misread, I thought he was trying to get to the switch.
mitsuki08
Last seen: 2 hours 53 min ago
Could you take a photo of the body and the inner tube? I just bought mine and I can’t seem to make mine work. Not 100% sure if mine is a first batch FW3A but mine doesn’t have the retaining ring on the tailcap. Looking at the 18650 and 18350 inner tubes, the 18350 protrudes more.
Tried to use the inner tube both ways and I can’t fully screw down the tail or the head where the thicker rim(bottom part on the 18350 tube in the image) is positioned at. I don’t know if it’s an incompatible inner tube or I’m doing something wrong.
Any advice?
JasonWW
JasonWW's picture
The inner tube should only work one direction, with the lip near the tail.
Is your oring under the lip on the smaller tube?
Tighten the tail cap first, then the head.
You can also tighten just the tail and then check to make sure the switch is working.
mitsuki08
Yes, my oring is under the lip on the smaller tube. I also tightened the tail cap first and it didn’t seem to do anything. Tightening it down just brings it to this.
Sorry I’m not sure what you mean by
Could you elaborate?
I tried to remove the oring from the lip under the inner tube and I can tighten it down further, I get a blink so i guess there is power but clicking the switch still does nothing.
JasonWW
JasonWW's picture
mitsuki08
JasonWW wrote:
Oh okay, so there is no beep to confirm the continuity when I click the switch. I tried to tighten it down more but I think it’s tightened well enough. Any suggestions to fix this?..
JasonWW
JasonWW's picture
mitsuki08 wrote:
Not really, maybe try with and without the oring. Maybe someone has an better idea.
M4D M4X
M4D M4X's picture
 it beeps between spring and the ring
spring to thread is always connected
deals.m4dm4x.com
MascaratumB
I just wanted to post some comparison photos that I took with the different tubes and clips and also side by side with the FW1A!
I really love these lights, did I mentioned it already? Wink
Enjoy! BTW, all of these (except the Sony battery) was bought from www.nealsgadgets.com Wink
Stuff I bought recently!
FW1A >>>>> FW3A
18350 tube
18500 tube
Tailcaps & Heads (FW1A has a retaining ring on the tail and the retaning ring on the driver is brass)
Tubes (FW3A > FW1A) [ yeah, they are different, but interchangeable, as far as I could test them and put them to work! Also, the clip on the FW1A is not dark, but it can be easily darkened with a blow torch, unlike the deep carry clip, that will probably take more efforts to do that! ]
FW1A 18350 & FW3A 18500 >>>> FW3A 18350 & FW1A 18500
The whole family Big Smile
SammysHP
SammysHP's picture
Last seen: 57 min 33 sec ago
Can you check if your retaining ring in the tailcap is centered and that the inner command tube fits inside of it? You can also try to put the command tube in first and then screw on the outer tube.
Firelight2
Firelight2's picture
Last seen: 7 min 53 sec ago
A rare possibility is a defective switch.
I had multiple FW3 lights with contact problems that were fixed by tightening the tube and tailcap.
However, that fix did NOT work on my Ti-Cu FW3T. Further checking revealed that the microswitch was actually defective.
  • It worked, but only if I pressed REALLY hard and even then only some of the time.
  • When I swapped the switch board for one from a different FW3 light the switch worked normally without excess pressure being needed.
  • I then swapped the defective board into a different FW3 light and it was still broken even though in a completely different light.
For this defective switch FW3 light I conclude that I need to desolder and remove the switch from the board and replace it with a different switch.
M4D M4X
M4D M4X's picture
i made a short video how to measure the current - hope its helpful for someone
deals.m4dm4x.com
JasonWW
JasonWW's picture
Your forgetting that his tail switch already works fine, as seen with the longer tube. It’s just the shorter tube that there is a contact problem.
You might try tightening harder.
You can check continuity with the battery tube removed, just slide the inner tube against the switch. That should definitely work.
Are both ends of the new tube clean and bare metal? No coatings or residue covering the contact area?
