GROUPBUY: 8pcs Samsung 35E BUTTON TOP for the BLF GT
281 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 5 hours 52 min ago
Hello my friends!
the BLF GT is near!
Who needs a set of 8 matching button top cells to power that beast?
the manufacturer of keeppower cells does the OEM job for us and adds the button tops to 4000 Samsung 35E cells:
(not the cheapest option - but we decided to go quality first on those sets)
UPDATE:
It seems we can offer the cells just beside the GT without confusing codes or such Smile
please be fair and DO NOT add them if you have not entered your mail in the list (which is mainly used to feel the demand)
Jump on the list when you want to pay 40 USD for a set of 8 cells, shipped nearly worldwide
only TOGETHER WITH THE BLF GT
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
Edited by: M4D M4X on 11/24/2017 - 05:06
Barkuti
Barkuti's picture
Last seen: 2 hours 24 min ago
While this may not be my business I believe that, since the GT uses a buck driver with 4S input feeding a 4S emitter, it may benefit from higher voltage cells like the Samsung ICR18650-30B or ICR18650-32A. I am pretty sure similar or even better runtime at least until out of regulation condition would be attained with these high voltage cells. It's terrible to see how did they choose such setup, the emitter driving voltage range overlaps with the cell dicharge range window and the driver isn't buck/boost. It's a shameful shoddy path they took just because the big cell pack plus powerful FET @#$% would have blown out the emitter.
This is just my opinion, of course.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
XXX-Man
XXX-Man's picture
Last seen: 8 hours 45 min ago
Can you tell from what store?
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
patmurris
patmurris's picture
Last seen: 19 hours 18 min ago
Interested – i used the form.
Nicolicous
Nicolicous's picture
Last seen: 8 min 59 sec ago
Ship to Australia?
Nico -.-
keengeorge
Last seen: 1 year 4 months ago
Interested, hopefully ship to Australia smile wink
FlashPilot
FlashPilot's picture
Last seen: 3 hours 55 min ago
Barkuti wrote:
While this may not be my business I believe that, since the GT uses a buck driver with 4S input feeding a 4S emitter, it may benefit from higher voltage cells like the Samsung ICR18650-30B or ICR18650-32A. I am pretty sure similar or even better runtime at least until out of regulation condition would be attained with these high voltage cells. It’s terrible to see how did they choose such setup, the emitter driving voltage range overlaps with the cell dicharge range window and the driver isn’t buck/boost. It’s a shameful shoddy path they took just because the big cell pack plus powerful FET @#$% would have blown out the emitter.
Cheers Party
I had the same thoughts as you. A sepic (buck/boost) regulator would have been the better choice, but also increased cost, complexity… and I suspect, introduced a myriad of unforeseen problems for the manufacturer. The limitations of maintaining regulation with the GT buck driver has also been discussed in the GT thread. You are correct, that the best performance of the GT will be realized while using cells that can maintain the highest voltage throughout the discharge curve. Keep in mind, that the discharge amps while using 8 cells in the GT will be about 1.5A per cell at max power. With that in mid, the Samsung 35E does a good job maintaining a high voltage while carrying a 1.5A load, especially for a 4.2V cell. Considering the availability of 4.30V and 4.35V cells, I was skeptical until I compared them against dozens of other cells using HKJ’s discharge comparator. Unless I missed something, the Samsung 35E is the better choice (and does not require a special charger to recharge them to max capacity).
Compare several 4.2V 18650 cells at the 1A and 2A discharge rates and see if you can find a cell that does an overall better job than the 35E.
http://lygte-info.dk/review/batteries2012/Common18650comparator.php
Also keep in mind that our eyes perceive light logarithmically, and probably wont be able to detect lumen variations in the field while using any of the top quality cells that most of us already use.
FlashPilot
Please PM price quote when available and add me to the list. Thank you.
g_sintornillos
g_sintornillos's picture
Last seen: 2 weeks 3 days ago
I am interested
If they are shipped to Uruguay, I will place two orders
Sorry for my bad English (gogole transtorla)
adsum
adsum's picture
Last seen: 6 days 17 hours ago
Interested if they ship to Finland.
AlexGT
AlexGT's picture
Last seen: 4 days 1 hour ago
Interested!
d_t_a
Last seen: 1 hour 30 min ago
Does price apply to shipping to the Philippines?
Itsme
Last seen: 3 hours 26 sec ago
any chance they will ship to Canada?
Zulumoose
Zulumoose's picture
Last seen: 5 months 4 weeks ago
Let me know if you have any way of shipping to South Africa.
Beam me up!
xxx
xxx's picture
Last seen: 1 year 6 months ago
8 cells around $40 shipped?
Interested
shirnask
shirnask's picture
Last seen: 25 min 4 sec ago
ssschen
ssschen's picture
Last seen: 1 month 5 days ago
Nicolicous wrote:
Ship to Australia?
I am in the same boat as my two fellow Aussie mates here. Not hopeful but I have put in my details too. Big Smile
Mike C
Mike C's picture
Last seen: 4 weeks 1 day ago
Interested. Entered my email in the form.
Caleb-v
Caleb-v's picture
Last seen: 4 months 2 days ago
Interested. Do you ship to New Zealand?
ilovejesuschrist
ilovejesuschrist's picture
Last seen: 11 months 3 weeks ago
Interested please Max
troisanh
Last seen: 1 year 1 month ago
interested and also filled out form, thanks M4D M4X.
Slayer1
Slayer1's picture
Last seen: 1 day 22 hours ago
Interested and filled out the form already.
patmurris
patmurris's picture
I already signed up for the unprotected BT 35E, but i would also be interested in protected ones if you can get us a deal on them too.
Persechini
Persechini's picture
Last seen: 11 months 2 weeks ago
Interested if shipped to Brazil
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
M4D M4X
M4D M4X's picture
i was told shipping to most countries...
Lights-Out
Lights-Out's picture
Last seen: 2 days 3 hours ago
Interested
Bribo
Bribo's picture
Last seen: 6 hours 8 min ago
I am in
xCentrino
xCentrino's picture
Interested Innocent
keengeorge
Great news!!  wink
Persechini
M4D M4X wrote:
i was told shipping to most countries…
Can you confirm the list? Brazil is one of those where most vendors only ship via dhl (over $40 for shipping) and regular $4~$8 shipping availability changes more or less on a monthly basis. BG and GB don’t ship at all
In my Tree
g_sintornillos
+1
Only very few AE sellers send batteries to Uruguay, less than the fingers of one hand
